Can't forward til mailbox or Digital Receptionist
Discussion in '3CX Phone System - General' started by lsiv, Sep 5, 2007.
  1. lsiv
    Sep 5, 2007
    can som please help here.... I can't forward to "voice mail" or the digital receptionist when the phone is unregistered!!! but it's works fine when i forward til a external number or an internal extension ???
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Do you think that IVR functionality depends on number of threads created?
    It is kind of joke :)
    You created two threads. Previous one describes a problem. Reason: IVR is not started or there is no connection between MediaServer and IVR.
    Fix it and everything will work.
    Regards
  3. lsiv
    Sep 5, 2007
    Hei Stephan,
    thanks for your reply! But what i IVR ?? i have six 3CX services... and all af them are started! how do i solve the problem ?
    sorry for being stuphid... but i'am total new on the 3CX system!
    Thanks in avanced,
    /Lars
  4. SY
    3CX Support
    Jan 26, 2007
    1,825
    If you see continuous messages:
    "service IVR not found (127.0.0.1:5483)"
    then connection to IVR (Digital Receptionist) is not established.
    Restart IVR (Digital Receptionist) service
    netstat -a -o
    there must be connection on port 5483 in listening state. PID - must be PID of 3CXIVRService process. If it is absent then someone blocks IVR to provide connection point.
    Regards
