17:59:24.730 [CM503020]: Normal call termination. Reason: Forbidden
17:59:24.730 [CM503016]: Call(1): Attempt to reach <sip:
[email protected]:5060> failed. Reason: Forbidden
17:59:24.729 [CM503003]: Call(1): Call to sip:
[email protected] has failed; Cause: 403 Forbidden; from IP:206.15.156.221:5060
17:59:24.713 [CM503025]: Call(1): Calling VoIPline:1626318xxxx@(Ln.10001@Broadvoice 626478xxxx)@[Dev:sip:
[email protected]:5060]
17:59:24.618 [CM503003]: Call(1): Call to sip:
17:59:24.557 [CM503025]: Call(1): Calling VoIPline:1626318xxxx@(Ln.10000@Broadvoice 626478xxxx)@[Dev:sip:
17:59:24.412 [CM503004]: Call(1): Route 2: VoIPline:1626318xxxx@(Ln.10001@Broadvoice 626478xxxx)@[Dev:sip:
17:59:24.412 [CM503004]: Call(1): Route 1: VoIPline:1626318xxxx@(Ln.10000@Broadvoice 626478xxxx)@[Dev:sip:
17:59:24.409 [CM503010]: Making route(s) to <sip:
17:59:24.408 [CM505001]: Ext.101: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14439.0] PBX contact: [sip:
17:59:24.406 [CM503001]: Call(1): Incoming call from Ext.101 to <sip:
