Solved Cant get an externalisieren outline with my yealink dect
Discussion in '3CX Phone System - General' started by Michael Walter, Apr 5, 2018.
  1. Michael Walter
    Mar 31, 2018
    15
    Searched everything, dont know.
    Ich make and Receiveinternal calls, can Receive external call , but cant make external calls.
    Also i habe set 3 internal Numbers, but only one recieves external call?
    Give me a big pain, we need to change from..... to 3cx. It was a decission.
    Please give me help for dummies
    Mike
    11,263
    359
    Not too clear on your issue, other than perhaps something to do with outbound rules, or the lack thereof. You will have to provide more details about your particular installation, type of trunks, local or cloud installation, etc.
    NickD_3CX likes this.
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,591
    309
    Seems like inbound rules - why only 1 number gets calls, and outbound rules - why outbound calls don't work. This is very vague...
  4. Michael Walter
    Mar 31, 2018
    15
    It is a local Installation
    Provider sipgate
    Yealink dect,
    Outbound rules???
  5. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,308
    216
  6. craigreilly
    Feb 1, 2012
    3,591
    309
  7. Saqqara
    Mar 12, 2014
    1,308
    216
    On the sip trunk setup, you have a section titled 'Route calls to' , you need to route calls to your required setup. If you want all phones to ring, create a ring group and add the required extensions into the ring group. change the sip setup to ring this group
    https://www.3cx.com/docs/manual/ring-groups-paging-intercom/
  8. craigreilly
    Feb 1, 2012
    3,591
    309
    ...and inbound rules.
  9. Saqqara
    Mar 12, 2014
    1,308
    216
    Agree, only required if the SIP line has DDI's associated with it. If OP only has one number , then SIP setup is enough,
  10. craigreilly
    Feb 1, 2012
    3,591
    309
    For some reason on my installs the main number is in Routing and DID as well.
  11. Saqqara
    Mar 12, 2014
    1,308
    216
    I believe if you have no DDI rule , it will use the default from the sip trunk. My setups have no DDI rules when only one number associated (no ddi's)
  12. craigreilly
    Feb 1, 2012
    3,591
    309
    Yep... makes sense as i read again. and I just noticed my trunk has 1aaabbbcccc and the DID rule has *aaabbbcccc. So, I do not think the trunk routing does anything... the numbers come in without the 1.
    If you have the rule in place, any changes to the rule change the inbound routing. <confirmed>
    Too many other things can get messed up in the Trunk if you get button happy.
    And to avoid confusion - 3cx does label them as DID... I haven't seen DDI anywhere. It does not look like the language packs changes them to DDI's for European languages.
  13. Michael Walter
    Mar 31, 2018
    15
    Problem solved
  14. leejor
    11,263
    359
    And it was...?
