Cant get DTMF tones to work?
Discussion in '3CX Phone System - General' started by seanbts, Oct 27, 2010.
  1. seanbts
    Oct 12, 2010
    34
    Hi All,
    Using Yealink T28's with 3CXmini and Blueface in Ireland as our Voip Provider, I cant get dtmf tones to work, the handsets are set to RFC2833 and so is our account with the provider. If i connect a yealink directly to our provider it works but not through 3cx, any one any ideas?
    Here's the log:
    14:59:16.953 [MS211000] C:24.1: 192.168.1.40:11780 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    14:59:15.234 [CM503007]: Call(24): Device joined: sip:xxxxxxxx@sip.blueface.ie:5060
    14:59:15.234 [CM503007]: Call(24): Device joined: sip:13@192.168.1.40:5062
    14:59:15.218 [CM505003]: Provider:[Generic VoIP Provider -] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:xxxxxxx@2xxxxxxxx:5060]
    10,356
    224
    Which end is not responding, places/numbers you are calling from a 3CX extension, or, incoming calls to your voicemail or automated attendant? If it is on outgoing calls...I would try changing the DTMF settings in the set, there are usually a number of different combinations that can be set. I assume that your codec is G711u/a ?
