Can't get Gigaset A580ip Setup as remote Extension
Discussion in '3CX Phone System - General' started by seanbts, May 12, 2011.
  1. seanbts
    Oct 12, 2010
    34
    Hi All,
    Anyone any idea how to configure the A580IP as a remote extension?
    Cheers
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    should be nice and easy, we have two of theses in service, all you will need to do is enter the public ip address in the correct boxes. Will do a screen shot for you tomorrow.
  3. seanbts
    Oct 12, 2010
    34
    Hi Dave,
    That would be great if you could put up a screenshot!
    thanks a mill
  4. davidbenwell
    Apr 27, 2010
    704
    here you go
    Replace 192.168.1.64 with your Public IP address of the 3CX server
    if you need to use a stun server, put in stun.3cx.com
      File size:
      40.5 KB
      1,002
      File size:
      13.4 KB
      1,002
  5. seanbts
    Oct 12, 2010
    34
    Hiya Dave,
    tried these with my public ip address but i get registration failed on both the gigaset phone and logs in 3cx. When i create the extension in 3cx do i need to enter in mac address as gigaset is not listed under the selected handsets?
    In the advanced settings on gigaset , sip port is 5060 and the rtp ports are 9000-9049?
    Thanks again
  6. davidbenwell
    Apr 27, 2010
    704
    yes that sould work, we have theses phones in a few remote locations, however would not recommend them for business usage, they seem to break down within 6-9 months of usage.
    no need to enter the mac address as the phones are not directly support by 3CX, however providing the both routers are setup correctly, you should have no issues.
    can you install the 3CX softphone on a remote pc and see if you can make and receive calls ok?
  7. seanbts
    Oct 12, 2010
    34
    Have it working now....had disable outside LAN ticked on the extension settings!
    Thanks again!
  8. davidbenwell
    Apr 27, 2010
    704
    ah right so you using the new V10 of 3CX :)
