Can't get inbound routes from voip.ms DID to work
Discussion in '3CX Phone System - General' started by Lee Moreau, Jul 23, 2012.
  1. Lee Moreau
    Jul 23, 2012
    27
    Just switched to 3CX from Asterisk but I cannot get my inbound DIDs to work at all with Voip.ms as a provider. It registers and I can make calls no problem but inbound just do not work at all. The log is pasted below, sorry it's long I think it keeps repeating, this is during an inbound call. It keeps giving authentication errors but the username and passwords are correct, and again I can make outbound calls fine just not receive inbound ones through the DID. What I don't get is how it says make sure the username and password match the ones in extension settings. What does that mean, what extension settings? It sounds like it's a setting in the Source ID field that needs to be set but I'm not really sure what I would need to change?
    22-07-2012 21:28:25.697 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:6477766305@10.0.0.75:5060 SIP/2.0
    Via: SIP/2.0/UDP 174.137.63.206:5060;branch=z9hG4bK3fe8b9c2;rport=5060
    Max-Forwards: 70
    Contact: <sip:7607058888@174.137.63.206>
    To: <sip:6477766305@10.0.0.75:5060>
    From: "UNKNOWN,UNKNOWN"<sip:7607058888@174.137.63.206>;tag=as6bb8fa87
    Call-ID: 05cc2db9335dbc9627b645596c57567e@174.137.63.206
    CSeq: 102 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
    Date: Mon, 23 Jul 2012 01:28:25 GMT
    Supported: replaces
    User-Agent: VoIPMS/SERAST
    Content-Length: 0
    Remote-Party-ID: "UNKNOWN,UNKNOWN" <sip:7607058888@174.137.63.206>;privacy=off;screen=no
    22-07-2012 21:28:24.729 [CM102001]: Authentication failed for INVITE sip:6477766305@10.0.0.75:5060 SIP/2.0
    Via: SIP/2.0/UDP 174.137.63.206:5060;branch=z9hG4bK53c17389;rport=5060
    Max-Forwards: 70
    From: "UNKNOWN,UNKNOWN"<sip:7607058888@174.137.63.206>;tag=as7b783724
    Call-ID: 2c0420cd14bd387247e7e6467bd04f41@174.137.63.206
    CSeq: 103 INVITE
    Content-Type: application/sdp
    Date: Mon, 23 Jul 2012 01:28:24 GMT
    Proxy-Authorization: Digest username="s",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:6477766305@24.212.188.142:49248",nonce="414d535c061d39b870:a811a6f827f526235115d64293320354",response="dd9f8876491350d312311824c9d223df"
    Supported: replaces
    Content-Length: 244
    v=0
    o=root 25896 25897 IN IP4 174.137.63.206
    s=session
    c=IN IP4 174.137.63.206
    t=0 0
    m=audio 15860 RTP/AVP 0 101
    a=rtpmap:0 PCMU/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-16
    a=silenceSupp:eek:ff - - - -
    a=ptime:20
    a=sendrecv
    ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    22-07-2012 21:28:24.729 [CM302002]: Authentication failed due to unidentified source of: INVITE sip:6477766305@10.0.0.75:5060 SIP/2.0
    Max-Forwards: 70
    CSeq: 103 INVITE
    Supported: replaces
    Content-Length: 244
    v=0
    s=session
    t=0 0
    a=fmtp:101 0-16
    a=ptime:20
    a=sendrecv
    22-07-2012 21:28:24.604 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 174.137.63.206:5060;branch=z9hG4bK5a40fdf5;rport=5060
    Max-Forwards: 70
    CSeq: 102 INVITE
    Supported: replaces
    Content-Length: 0
    22-07-2012 21:28:23.682 [CM102001]: Authentication failed for INVITE sip:6477766305@10.0.0.75:5060 SIP/2.0
    Via: SIP/2.0/UDP 174.137.63.206:5060;branch=z9hG4bK17961d4a;rport=5060
    Max-Forwards: 70
    From: "UNKNOWN,UNKNOWN"<sip:7607058888@174.137.63.206>;tag=as31e1ea2a
    Call-ID: 770d29ca4d5cc1001cedc3cc6b534294@174.137.63.206
    CSeq: 103 INVITE
    Date: Mon, 23 Jul 2012 01:28:23 GMT
    Proxy-Authorization: Digest username="s",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:6477766305@24.212.188.142:49248",nonce="414d535c061d39b763:4ba54ef039184bc1fda74edb39313e1c",response="97db8b34f9a0de22d4207c1b32564d51"
    Supported: replaces
    Content-Length: 244
    v=0
    s=session
    t=0 0
    m=audio 18644 RTP/AVP 0 101
    a=fmtp:101 0-16
    a=ptime:20
    a=sendrecv
    22-07-2012 21:28:23.682 [CM302002]: Authentication failed due to unidentified source of: INVITE sip:6477766305@10.0.0.75:5060 SIP/2.0
    Max-Forwards: 70
    CSeq: 103 INVITE
    Supported: replaces
    Content-Length: 244
    v=0
    s=session
    t=0 0
    a=fmtp:101 0-16
    a=ptime:20
    a=sendrecv
    22-07-2012 21:28:23.557 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 174.137.63.206:5060;branch=z9hG4bK0addc96a;rport=5060
    Max-Forwards: 70
    CSeq: 102 INVITE
    Supported: replaces
    Content-Length: 0
    22-07-2012 21:28:22.635 [CM102001]: Authentication failed for INVITE sip:6477766305@10.0.0.75:5060 SIP/2.0
    Via: SIP/2.0/UDP 174.137.63.206:5060;branch=z9hG4bK5483c603;rport=5060
    Max-Forwards: 70
    From: "UNKNOWN,UNKNOWN"<sip:7607058888@174.137.63.206>;tag=as58559899
    Call-ID: 595bb1933ff5470f463d467c3a560b3f@174.137.63.206
    CSeq: 103 INVITE
    Date: Mon, 23 Jul 2012 01:28:22 GMT
    Proxy-Authorization: Digest username="s",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:6477766305@24.212.188.142:49248",nonce="414d535c061d39b687:c3a0d6e799769c518663350dd4a1ce68",response="62dce515d001e19ba188e6ec7845c65d"
    Supported: replaces
    Content-Length: 244
    v=0
    s=session
    t=0 0
    m=audio 31460 RTP/AVP 0 101
    a=fmtp:101 0-16
    a=ptime:20
    a=sendrecv
    22-07-2012 21:28:22.635 [CM302002]: Authentication failed due to unidentified source of: INVITE sip:6477766305@10.0.0.75:5060 SIP/2.0
    Max-Forwards: 70
    CSeq: 103 INVITE
    Supported: replaces
    Content-Length: 244
    v=0
    s=session
    t=0 0
    a=fmtp:101 0-16
    a=ptime:20
    a=sendrecv
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Have you double checked when you added the DIDs the the auth id code is corect? It looks lke and error in t log
  3. unoa
    Oct 14, 2009
    22
    Hi Lee,
    Are u sure you are using a Supported VOIP provider? I have had the same issue with a unsupported provider which I eventually did not get to work. Give Voip.ms a call and ask them what the correct settings for 3cX should be. If they don't know 3cX I advice you to port your numbers to a (by 3cX) supported VOIP provider. Check the following list:
    http://www.3cx.com/partners/voip-providers.html
  4. Lee Moreau
    Jul 23, 2012
    27
    I actually got it working finally. Under Source ID under my voip provider's main page I had to check the box Source Identification by DID and then add all the DIDs there and that made it work.
  5. bogart99j
    Aug 27, 2012
    Lee - thanks for the tip.. This one had me baffled... works like a champ
  6. jpillow
    Jun 20, 2011
    1,342
    HAving the same problem but cannot find the box to check on the VoIP ms customer portal and their support teams says it doesnt exist. These guys arent the brightest. thanks for the help!!!!
  7. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    JP-
    I think he means here (on 3CX Voip tab) - see attached
  8. DBOD
    Jul 31, 2012
    45
    I also had to add the DID to the list of DIDS it uses for source Id. At first I only added the 10 digit DID and it did not work until I added the 1 in front of it. I did not try it with a mask or wild cards.
  9. jpillow
    Jun 20, 2011
    1,342
    Yeah kind of in a rush that day and misread got i tfigured out right after I posted that in forum. Call centric went out that day and this was the work around. No issues since. Thanks!
  10. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    252
    Today, I set up a new DID and had to use 10 digits with them.
    I decided to use *DID just in case it ever changes.
