Can't Get Paging to Work.
Discussion in '3CX Phone System - General' started by MichaelD, Jun 12, 2011.
  1. MichaelD
    Mar 27, 2010
    36
    I upgraded to v10, and can't get paging to work.
    I set up a Ring group (virtual machine number 90) with the Ring Strategy of Paging. I then added all the extensions as members.
    But when I dial 90, it rings the extensions, instead of paging them. I know I had this working at one time in v8, but don't remember how.
    What am I doing wrong?
  2. willow
    willow Member
    Mar 1, 2011
    471
    there may be a setting on the phone that needs to be tweeked. what type of phones are you using?
  3. MichaelD
    Mar 27, 2010
    36
    Snom 870s and 820s.
  4. willow
    willow Member
    Mar 1, 2011
    471
    if you want to configure the phone manually, look for "´Answer After´ Policy" setting in the Snom (it is at the "Behaviour" tab of Adanced settings).
  5. MichaelD
    Mar 27, 2010
    36
    Thank you for the reply, but I have no "Answer After" on the Behavior tab in Advances settings. I am running the latest firmware in both the 820s and 870s.
