Can't get the 3CX System to register the 3CX Client.
Discussion in '3CX Phone System - General' started by gcl, Dec 11, 2007.
  1. gcl
    gcl
    Dec 11, 2007
    Installed the 3CX V5 System and the Client on the same PC.
    Running Windows XP Pro, Ver 2002, SP2, no firewall, DEP set for essential Windows services ony.
    Set the parameters according to the manual - best ability.
    Some parameters not well documented.
    I'm not a network or SIP guru.
    I did get Brekeke to work, but it has a 60 day limit.
    Can't get the Client to register.Considering switching to YATE.
    Any ideas/comments?
    Thanks.
  2. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Comment 1 - why are you putting the PBX and the client on the same PC? If you're going to do that, at least run it in a VM!!
