Can't get the software to work
Discussion in '3CX Phone System - General' started by josersbf, Jan 2, 2007.
  1. josersbf
    Oct 13, 2006
    It doesn't register my sip provider and I can't register the extensions using the x-lite.
  2. npiersma
    Dec 30, 2006
    55
    I can imagine your problem. But without more detail I (nor anyone) will be able to assist.
    I've still got some issues laying around, but registering two softphones and calling each other is fairly straight foreward.
    Did you use the step by step guide provided in the manual?
    And if so, where did you got lost. I might be able to help you out.
    Niels
  3. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    getting the X-lite phone to work is the easy part. I still have not gotten my Grandstream HT-488 to work with the IP PBX.
    Just follow the guide like he said. Now anyone want to help me with my ATA?
    Cjammer
  4. ihq-it
    Mar 30, 2007
    ever get your HT488 working?
    I too have bought a HT488. FXS works fine, FX0 doesn't! Any ideas?
