Can't get to forwarding rules in MyPhone
Discussion in '3CX Phone System - General' started by craigreilly, Dec 12, 2012.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,407
    274
    Anyone have the "Forwarding Rules" greyed out in MyPhone ?
    This is not the "Hide Forwarding Rules" checkbox from the extension - I tried that. That actually removed the tab. This is just simply disabled. Also the "Actions" pane is disabled at the bottom, as is "Email Options" for Voicemail.
    Workstation is Windows 7 Pro 64bit.
    EDIT
    Ok, so a reboot took care of this issue. Note, completely closing 3cx MyPhone; ensuring it was not running, then restarting it did not change this behavior.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Free licence?
  3. craigreilly
    Feb 1, 2012
    3,407
    274
    Nope - 64 license version.
    It was fine elsewhere - I checked 20 other computers.
    It could be that my machine stays on 24/7 and usually logged in, as I remote in on the weekend when needed.
  4. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    I think it's a sylverlight issue. Try to uninstall myphone and sylverlight and install them again.
  5. craigreilly
    Feb 1, 2012
    3,407
    274
    Dan,
    Once I rebooted all was ok. Very strange for sure.
