Can't Hear Caller
Discussion in '3CX Phone System - General' started by refiking, Jul 18, 2008.
  1. refiking
    Jul 2, 2008
    12
    Inside the LAN, the caller can hear me fine. However, outside is another story. I can hear them clearly. I setup the port forward for 5060 and 9000-9015 UDP. I've performed the firewall test and that passed with no problems. Not sure what else I am supposed to do. Please advise 3CX gurus...
  2. justin
    Feb 20, 2008
    79
    When you call them or they call you or both?
  3. francesco
    francesco New Member
    Jun 23, 2008
    102
    you setup STUN server?
  4. refiking
    Jul 2, 2008
    12
    To Justin:
    Outbound calls aren't working at all.
    To Francesco:
    How do I setup the STUN server? I thought it was automatically done.
  5. overkill
    Oct 24, 2007
    I have same issue here.
    The problem is,one option in my firewall screw up everthing.
    Turn it ON this option in your firewall if you have it "DONT TRANSLATE SOURCE IP"
    Making this i fixed the problem.
  6. refiking
    Jul 2, 2008
    12
    I have a Motorola WR850G router and I checked the manual and even googled it, but can't this option. Does the system need to be on another router or something? Please advise.
