CAN'T INSTALL ERROR 2755
Discussion in '3CX Phone System - General' started by tester009, Sep 1, 2008.
  1. tester009
    Sep 1, 2008
    I tried installing this on Vista Premium and near the end of the install I get a error telling me that the package has a error 2755.
    Can any one help with this?
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I'm afraid your vista does not support
    please read
    http://www.3cx.com/support/operating-systems.html
  3. Discovery Technology
    Apr 19, 2008
    278
    Try my entry in the following forum - it may help:
    http://www.3cx.com/forums/3cx-voip-client-v6-0-available-4998.html
    ...and make sure that UAC is switched off (we do this as a standard in Vista as it just helps in most cases with just about anything you want to install on it)
    Cheers, Brendan
