Solved Cant login to 3cx cloud
Discussion in '3CX Phone System - General' started by Jiveman, Aug 25, 2017.
  1. Jiveman
    Aug 24, 2017
    13
    We cant seem to login to our 3cx cloud pabx. The url is xxxx.3cx.co.nz. All our phones are down. When we try to login the error is
    WARNINGS.SERVER_ERROR
    WARNINGS.WEB_SERVER_NOT_RESPONDING
    We were doing some changes to international outbound rules yesterday and all seems to work ok. However the system has been down all of today. Any ideas ?
    TIA
  2. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi @Jiveman ,
    Was your instance created using the PBX Express and hosted under the 3CX Trial Account?
  3. Jiveman
    Aug 24, 2017
    13
    Yes that is correct. We want to evaluate the product before we do a full scale migration
  4. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    Hi again,
    As per the note on the PBX Express wizard, instances created under the 3CX Trial Account are valid for 29 days only.
    I assume that is the reason you cannot access your cloud machine.
    (If the 29 days did not pass and you cannot access the PBX then we should troubleshoot.)
    Jiveman likes this.
  5. Jiveman
    Aug 24, 2017
    13
    Yes it would be about that time. We will now look at buying the licensed version.
    Thank you for your help !
  6. agp
    agp 3CX Team
    Aug 19, 2015
    151
    22
    You are welcome :)
