Can't make any calls
Discussion in '3CX Phone System - General' started by andrewseni, Aug 19, 2008.
  1. andrewseni
    Aug 14, 2008
    17
    My 3CX system shows the VOIP line & extension as registered, but I can't make calls either internally or externally - everything comes up as a 403 error/busy.
    The log shows things like: Incoming call rejected, caller is unknown; msg=SipReq: INVITE 888@sip.xxxx.com tid=7ffcff1403d29ba2 cseq=INVITE contact=123@192.168.0.106:5060 / 12183 from(wire)
    [CM302001]: Authorization system can not identify source of: SipReq: INVITE 888@sip.xxxx.com tid=f583f6fcdc59df24 cseq=INVITE contact=123@192.168.0.106:5060 / 7997 from(wire)
    I have obviously made a basic setup mistake, but I don't know what it is!
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    try to close the firewall
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    Maybe you should consider a commercial version with tech support. Then you will get assistance in setting up 3Cx and this will save you time getting all up and running.
