Can't make call OUTSIDE
Discussion in '3CX Phone System - General' started by Tugi2o, Jul 9, 2010.
  1. Tugi2o
    Feb 20, 2007
    61
    since the update to latest version of 3cx phone system i have a lot of problems when i'am calling outside.
    i use german voip provider.
    there are two possibilities:
    - i dial a number (for example my mobile phone) in 3cx phone...in my headset of 3cx phone i can hear the ringing signal, but my mobile phone does not ring
    - i dial a number (for example my mobile phone) in 3cx phone...my mobile phone is ringing...when i take the call on my mobile phone, the call is terminated.
    Here's the protocoll:
    11:05:24.390 [CM503020]: Normal call termination. Reason: Terminated
    11:05:24.390 [CM503016]: Call(51): Attempt to reach <sip:0176XXX37346@192.168.0.150:5060> failed. Reason: User Requested
    11:05:24.375 [CM503003]: Call(51): Call to sip:0176XXX37346@07021.sip.arcor.de:5060 has failed; Cause: 200 OK; from IP:212.XXX.96.124:5060
    11:05:10.984 [CM505003]: Provider:[Arcor 07021 XXX0744] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:07021XXX0744@192.168.0.150:5060]
    11:05:07.406 [CM503025]: Call(51): Calling VoIPline:0176XXX37346@(Ln.10009@Arcor 07021 XXX0744)@[Dev:sip:07021XXX0744@07021.sip.arcor.de:5060]
    11:05:07.250 [CM503004]: Call(51): Route 1: VoIPline:0176XXX37346@(Ln.10009@Arcor 07021 XXX0744)@[Dev:sip:07021XXX0744@07021.sip.arcor.de:5060]
    11:05:07.218 [CM503001]: Call(51): Incoming call from Ext.50 to <sip:0176XXX37346@192.168.0.150:5060>
    Has anyone an idea???
    With latest V8 we had not such problems...
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    174
    since it is an unsupported provider pls send us a wireshark capture.
    One from a version 8 and other from version 9.
  3. Tugi2o
    Feb 20, 2007
    61
    Now i downgraded to V8 and have the same problems...so i think, that my provider changed s.th.
