cant make calls from external VoIP Phone
Discussion in '3CX Phone System - General' started by teh_spartan, Sep 3, 2010.
  1. teh_spartan
    Sep 3, 2010
    25
    i can't make calls or receive calls from an external ip. I have every port open in tcp and udp. the phone registers but it wont make the calls. this same phone works when on my internal network.
    10,375
    231
    Did you enabled STUN on the phone when you moved it off of the local LAN. You need to. What does the registration or a call attempt look like in the 3CX logs?
  3. teh_spartan
    Sep 3, 2010
    25
    I should probably make this clear, the calls i am trying to make are between extensions. because I don't have a PTSN device yet
    what should my STUN settings look like?
    the log looks like this.
    it also fails when i am using the server domain (http://www.mydomain.com) instead of the local ip (192.168.xxx.xxx) on my phone
    17:17:46.453 [CM502001]: Source info: From: "Derek's iPhone"<sip:101@(www.mydomain.com)>;tag=35E15679B31452C163CB1C84EACF393D<sip:100@(www.mydomain.com)>
    17:17:46.453 [CM503013]: Call(34): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 100@(www.mydomain.com) tid=AkgNRGYSyLqKECLk cseq=INVITE contact=101@(192.168.xxx.xxx):49696 / 2 from(wire)
    my settings look like this (I censored out the server information)
    [​IMG][​IMG]
  4. teh_spartan
    Sep 3, 2010
    25
    i am sorry i didn't see that this was only for v9 with video my bad i will just repost in the right forum.
    :oops:
