Can't make Calls to 800 877 or 866 Toll Free Numbers
Discussion in '3CX Phone System - General' started by brian595, Jun 24, 2009.
  1. brian595
    Jun 22, 2009
    I can't make calls to any toll free numbers it appears. I have two different sip trunks. And I can make long distance calls just fine. I've even made some Outbound rules for the 800 numbers. Any ideas? Thanks in adavance.
    Code:
    15:27:09.477  [CM503008]: Call(17): Call is terminated
    15:27:09.461  [CM503015]: Call(17): Attempt to reach <sip:18775328829@192.168.20.5> failed. Reason: Not Found
    15:27:09.461  [CM503003]: Call(17): Call to sip:+18775328829@4.55.13.163:5060 has failed; Cause: 404 Not Found; from IP:4.79.132.209:5060
    15:27:08.524  [CM503016]: Call(17): Target is not registered: VoIPline:18775328829 dialed on (AnyLine@NexVortex Test)
    15:27:08.524  [CM303003]: There are no available outbound lines on gateway NexVortex Test at this time.
    15:27:08.524  [CM503024]: Call(17): Calling VoIPline:18775328829@(Ln.10000@Sotel)@[Dev:sip:4352284648@termination.sotelips.net:5060]
    15:27:08.524  [MS210002] C:17.2:Offer provided. Connection(transcoding mode): 209.33.198.125:9020(9021)
    15:27:07.196  [CM503004]: Call(17): Route 1: VoIPline:18775328829@(Ln.10000@Sotel)@[Dev:sip:4352284648@termination.sotelips.net:5060]
    15:27:07.180  [MS210000] C:17.1:Offer received. RTP connection: 192.168.20.128:16452(16453)
    15:27:07.180  [CM503010]: Making route(s) to <sip:18775328829@192.168.20.5>
    15:27:07.164  Remote SDP is set for legC:17.1
    15:27:07.164  [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] Transport: [sip:192.168.20.5:5060]
    15:27:07.164  [CM503001]: Call(17): Incoming call from Ext.100 to <sip:18775328829@192.168.20.5>
    15:27:07.164  [CM500002]: Info on incoming INVITE:
      INVITE sip:18775328829@192.168.20.5 SIP/2.0
      Via: SIP/2.0/UDP 192.168.20.128:5060;branch=z9hG4bK-6ca9f538
      Max-Forwards: 70
      Contact: "100"<sip:100@192.168.20.128:5060>
      To: <sip:18775328829@192.168.20.5>
      From: "100"<sip:100@192.168.20.5>;tag=d87b8d3e848c1760o0
      Call-ID: 8091d116-cfae568@192.168.20.128
      CSeq: 102 INVITE
      Expires: 240
      Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
      Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c00532b2b12:ad585b9eb8e08864443a5e5090d8a13c",uri="sip:18775328829@192.168.20.5",algorithm=MD5,response="1d304dc9e9f00cf691d0bf98151f8bfb"
      Supported: replaces
      User-Agent: Linksys/SPA942-6.1.5(a)
      Content-Length: 0
    10,758
    286
    Are you getting :
    Every time you attempt a toll free call?
    Do you have that particular trunk group set up to allow more than one call at a time? I also noticed the + in front of the outbound number. Are you placing calls from within North America? if so, does your provider require the international access code before the number. With the +, the next "1" becomes the code for North America not the LD access prefix. What does a working LD call show, do you see the + in the log?
  3. brian595
    Jun 22, 2009
    I am placing the calls inside North America. Here is a successful long distance call.
    Code:
    11:34:03.712  [CM503008]: Call(28): Call is terminated
    11:34:03.696  [CM503008]: Call(28): Call is terminated
    11:34:01.337  Session 23366 of leg C:28.1 is confirmed
    11:34:01.228  [CM503007]: Call(28): Device joined: sip:4352284648@termination.sotelips.net:5060
    11:34:01.228  [CM503007]: Call(28): Device joined: sip:100@192.168.20.128:5060
    11:34:01.228  [MS210001] C:28.2:Answer received. RTP connection: 4.55.6.6:11500(11501)
    11:34:01.228  Remote SDP is set for legC:28.2
    11:34:00.275  [MS210003] C:28.1:Answer provided. Connection(transcoding mode):192.168.20.5:7062(7063)
    11:34:00.275  [MS210001] C:28.2:Answer received. RTP connection: 4.55.6.6:11500(11501)
    11:34:00.275  Remote SDP is set for legC:28.2
    11:34:00.275  [CM505003]: Provider:[Sotel] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.20.5:5060]
    11:34:00.275  [CM503002]: Call(28): Alerting sip:4352284648@termination.sotelips.net:5060
    11:33:56.696  [CM503016]: Call(28): Target is not registered: VoIPline:18015752400 dialed on (AnyLine@NexVortex Test)
    11:33:56.696  [CM303003]: There are no available outbound lines on gateway NexVortex Test at this time.
    11:33:56.696  [CM503024]: Call(28): Calling VoIPline:18015752400@(Ln.10000@Sotel)@[Dev:sip:4352284648@termination.sotelips.net:5060]
    11:33:56.696  [MS210002] C:28.2:Offer provided. Connection(transcoding mode): 209.33.198.125:9040(9041)
    11:33:56.368  [CM503004]: Call(28): Route 1: VoIPline:18015752400@(Ln.10000@Sotel)@[Dev:sip:4352284648@termination.sotelips.net:5060]
    11:33:56.337  [MS210000] C:28.1:Offer received. RTP connection: 192.168.20.128:16466(16467)
    11:33:56.337  [CM503010]: Making route(s) to <sip:18015752400@192.168.20.5>
    11:33:56.337  Remote SDP is set for legC:28.1
    11:33:56.337  [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] Transport: [sip:192.168.20.5:5060]
    11:33:56.321  [CM503001]: Call(28): Incoming call from Ext.100 to <sip:18015752400@192.168.20.5>
    11:33:56.321  [CM500002]: Info on incoming INVITE:
      INVITE sip:18015752400@192.168.20.5 SIP/2.0
      Via: SIP/2.0/UDP 192.168.20.128:5060;branch=z9hG4bK-cf84432e
      Max-Forwards: 70
      To: <sip:18015752400@192.168.20.5>
      From: "100"<sip:100@192.168.20.5>;tag=b86b2db8c95dde6o0
      Call-ID: e286dfa0-e8c7951e@192.168.20.128
      CSeq: 102 INVITE
      Expires: 240
      Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c0054460476:6a30ec51950fb11f5e11ef8f54cc8bd8",uri="sip:18015752400@192.168.20.5",algorithm=MD5,response="6b3705f4c23ce522d32ee2766735ca19"
      Supported: replaces
      Content-Length: 0
    So it doesn't appear to have the + sign in front of it. Is that not allowing me to make the calls?
  4. brian595
    Jun 22, 2009
    I tried making a call without the prefix 1 which appears to eliminate the +, but it still doesn't allow the call to go through.
    Code:
    11:57:18.812  [CM503008]: Call(31): Call is terminated
    11:57:18.812  [CM503015]: Call(31): Attempt to reach <sip:8775328829@192.168.20.5> failed. Reason: Not Found
    11:57:18.812  [CM503003]: Call(31): Call to sip:+18775328829@4.55.13.163:5060 has failed; Cause: 404 Not Found; from IP:4.79.132.209:5060
    11:57:17.891  [CM503016]: Call(31): Target is not registered: VoIPline:8775328829 dialed on (AnyLine@NexVortex Test)
    11:57:17.891  [CM303003]: There are no available outbound lines on gateway NexVortex Test at this time.
    11:57:17.891  [CM503024]: Call(31): Calling VoIPline:8775328829@(Ln.10000@Sotel)@[Dev:sip:4352284648@termination.sotelips.net:5060]
    11:57:17.875  [MS210002] C:31.2:Offer provided. Connection(transcoding mode): 209.33.198.125:9046(9047)
    11:57:17.422  [CM503004]: Call(31): Route 1: VoIPline:8775328829@(Ln.10000@Sotel)@[Dev:sip:4352284648@termination.sotelips.net:5060]
    11:57:17.406  [MS210000] C:31.1:Offer received. RTP connection: 192.168.20.128:16472(16473)
    11:57:17.406  [CM503010]: Making route(s) to <sip:8775328829@192.168.20.5>
    11:57:17.406  Remote SDP is set for legC:31.1
    11:57:17.391  [CM505001]: Ext.100: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA942-6.1.5(a)] Transport: [sip:192.168.20.5:5060]
    11:57:17.391  [CM503001]: Call(31): Incoming call from Ext.100 to <sip:8775328829@192.168.20.5>
    11:57:17.391  [CM500002]: Info on incoming INVITE:
      INVITE sip:8775328829@192.168.20.5 SIP/2.0
      Via: SIP/2.0/UDP 192.168.20.128:5060;branch=z9hG4bK-4efedd23
      Max-Forwards: 70
      To: <sip:8775328829@192.168.20.5>
      From: "100"<sip:100@192.168.20.5>;tag=307dec22838145cfo0
      Call-ID: 215c2cde-b03b9c43@192.168.20.128
      CSeq: 102 INVITE
      Expires: 240
      Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c00544b7d06:714febdad53c4df31d6c8367b31a9974",uri="sip:8775328829@192.168.20.5",algorithm=MD5,response="94bc47405e1b2f95c0349c5bf79cdc0f"
      Supported: replaces
      Content-Length: 0
  5. brian595
    Jun 22, 2009
    It appears it was a problem with the Sip Trunk :roll: . I got a new DID number from them and everything works. Thanks for your help.
  6. leejor
    10,758
    286
    When you get messages like the "no trunks available" you have to start thinking that it just might be your provider, glad you got it resolved.
