Can't Make Calls with LinkSys 3202
Discussion in '3CX Phone System - General' started by bblokey, Apr 25, 2008.
  1. bblokey
    Apr 15, 2008
    57
    I am having issues making outbound calls. My incoming is working fine and my setup includes a psp2 for my analog line. I have the phone line port going to my gateway line port.
    Looks like maybe my gateway is not setup correctly. What do you think?
    Time Function Message
    23:10:35.032 Call::Terminate [CM503008]: Call(4): Call is terminated
    23:10:35.016 Call::RouteFailed [CM503014]: Call(4): Attempt to reach [sip:9726210252@192.168.0.106:5060] failed. Reason: Not Found
    23:10:35.016 CallLeg::eek:nFailure [CM503003]: Call(4): Call to sip:9726210252@192.168.0.100:5060 has failed; Cause: 404 Not Found; from IP:192.168.0.100:5060
    23:10:34.922 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(4): Calling: PSTNline:10000@[Dev:sip:10000@192.168.0.100:5060]
    23:10:34.907 CallCtrl::eek:nIncomingCall [CM503001]: Call(4): Incoming call from Ext.501 to [sip:9726210252@192.168.0.106:5060]
  2. bblokey
    Apr 15, 2008
    57
    NM... I found my problem and I am able to make external calls... :p
  3. ktornqvist
    Apr 11, 2008
    what was the prob ?
  4. bblokey
    Apr 15, 2008
    57
    On my gateway I had line 1 and my pstn line using the same port. Which caused the system to try and route my outbound call to line 1 which it could not resolve.
  5. arpa
    Feb 14, 2008
    35
    You must not use the same port for the Line 1 and PST Line. That's why you have the problem. In the 3CX Forums i found the solution. Here is the link
    http://www.3cx.com/forums/spa-3102-outgoing-2061-15.html
    You must use SIP port 5061 for the Line 1 and 5060 for the PSTN
