Can't make out going calls
Discussion in '3CX Phone System - General' started by glennbtn, Jun 10, 2008.
  1. glennbtn
    Mar 14, 2008
    Hi I have v5.1 installed on a xp sp2 machine with 1 snom phone as an extension and 3cx software phone. The sip is connected to voiptalk and I can recieve incoming calls but can't make any out going 1's. I have setup the outbound rules and everycall just ends with a time out
    CM503003]: Call(7): Call to sip:9200@voiptalk.org:5060 has failed; Cause: 408 Request Timeout; internal
    [CM503014]: Call(7): Attempt to reach [sip:9200@10.10.10.4;user=phone] failed. Reason: No Answer
    Can anyone help?
    Glenn
