Can't make outbound calls from extension to PSTN
Discussion in '3CX Phone System - General' started by brianfpmoab, Apr 11, 2007.
  1. brianfpmoab
    Mar 15, 2007
    17
    I have 3CX v3.0.1699.0 installed and configured for 2 extensions and 7PSTN lines via 2 PSTN gateways. I can successfully make calls from an outside line (cell phone, home phone etc) to any of the lines connected to either of the gateways and am passed into the PBX just fine. I can call from extension to extension just fine. I have an outbound rule for each gateway that routes calls to each gateway and strips the first digit off. The problem is that when I make a call from either extension I get the following in the log.
    07:34:05.140 CallConf::Rejected Call (C:11) is rejected: Not Found
    07:34:05.140 StratInOut::eek:nCancel Call from Ext.103 to 2594384 has been terminated; reason: Not Found
    07:34:02.531 CallConf::eek:nIncoming Incoming call from Ext.103 to sip:92594384@xxx.xxx.xxx.138
    The devices are on the same network subnet. The phone, gateway, and PBX are connected to the same switch. I do not have a firewall running on the PBX.
    My question is: Is this a problem in the configuration of the PBX, or in one of the hardware devices (ATA adaptor or Gateway)?
    I have only added 2 extensions for testing . When the system is up and running I will have 12-15 extensions.
    Brian
  2. NigelG
    Mar 29, 2007
    48
    RE: Problem
    Hi Brian,
    In the help file under troubleshooting, the following seems to match your problem which indicates that your PSTN Gateway is unable to dial the requested number:
    b. Failed call: VoIP provider can not dial specified number
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Hi Brian,
    Nigel is right. Your device rejects numbers you've dialled by some reason. Please, tell us what exactly device do you have, and what are your 3CX settings (including Advanced options) for that device. Than we probably can suggest how to set things up.
  4. brianfpmoab
    Mar 15, 2007
    17
    Nigel and Archie,
    Here are the settings in 3CX for the gateway.
    VOIP Gateway
    Gateway Hostname or IP: xx.xx.xx.131
    Gateway Port: 5060
    Advanced Options
    Config template: Generic
    Device is external: unchecked
    Bind to Media Server: unchecked
    Use IP in 'Contact' to recognize source: Checked
    Caller-ID is in
  5. brianfpmoab
    Mar 15, 2007
    17
    Nigel and Archie,
    Thank you for pointing me in the right direction. I was able to get everything to work.
    Just FYI for anyone else using an AudioCodes gateway. I was not able to make outbound calls from an extension with the errors mentioned in the first post. The solution was in the AudioCodes device in the IP to hunt group routing table. I ended up making the dest prefix, source prefix and source ip all * and the hunt group ID of 1 which I had setup earlier.
    Thanks again!
    Brian
  6. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    Brian,
    I have the same device and can call out but will not accept incoming calls. Can you either send me or post your ini file for MP-118?
    Mike
    Got It working finally!!!
    For anyone else with the same hardware here is the ini file:
    ;** Ini File **
    ;Board: MP-118 FXO
    ;Serial Number: 761897
    ;Slot Number: 1
    ;Software Version: 5.00A.031.003
    ;DSP Software Version: 204IM => 209.16
    ;Board IP Address: 192.168.80.15
    ;Board Subnet Mask: 255.255.255.0
    ;Board Default Gateway: 192.168.80.1
    ;Ram size: 32M Flash size: 8M
    ;Num DSPs: 2 Num DSP channels: 8
    ;Profile: NONE
    [SYSTEM Params]
    NTPServerIP = 192.168.80.10
    TelnetServerEnable = 1
    ActivityListToLog = 'pvc', 'dr', 'fb', 'swu', 'spc'
    [BSP Params]
    PCMLawSelect = 3
    BaseUDPPort = 6000
    LocalOAMIPAddress = 192.168.80.15
    LocalOAMSubnetMask = 255.255.255.0
    LocalOAMDefaultGW = 192.168.80.1
    RoutingTableHopsCountColumn = 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
    [ATM Params]
    [Analog Params]
    FXOLoopCharacteristicsFilename = 'MP1xx12-1-16khz-fxo.dat'
    FlashHookPeriod = 500
    [ControlProtocols Params]
    MGCPDTMFDetectionPoint = 0
    AdminStateLockControl = 0
    [MGCP Params]
    [MEGACO Params]
    EP_Num_0 = 0
    EP_Num_1 = 1
    EP_Num_2 = 0
    EP_Num_3 = 0
    EP_Num_4 = 0
    [PSTN Params]
    [SS7 Params]
    [Voice Engine Params]
    EnableContinuityTones = 1
    IdlePCMPattern = 255
    L1L1ComplexRxUDPPort = 0
    L1L1ComplexTxUDPPort = 0
    EnableSilenceCompression = 0
    EnableEchoCanceller = 1
    ECHybridLoss = 1
    VoiceVolume = 20
    InputGain = -12
    DTMFVolume = -20
    DTMFTransportType = 3
    MFTransportType = 3
    CallerIDTransportType = 1
    V22ModemTransportType = 0
    V23ModemTransportType = 0
    V32ModemTransportType = 0
    V34ModemTransportType = 0
    FaxRelayECMEnable = 0
    BasicRTPPacketInterval = 0
    CNGDetectorMode = 1
    DJBufMinDelay = 20
    DJBufOptFactor = 13
    RTPRedundancyDepth = 0
    RTPPackingFactor = 1
    RTPDirectionControl = 0
    RFC2833PayloadType = 101
    RFC2833TxPayloadType = 96
    RFC2833RxPayloadType = 96
    RFC2198PayloadType = 104
    FaxBypassPayloadType = 102
    EnableStandardSIDPayloadType = 0
    EnableAnswerDetector = 1
    AnswerDetectorActivityDelay = 0
    AnswerDetectorSilenceTime = 10
    AnswerDetectorRedirection = 0
    AnswerDetectorSensitivity = 0
    AnalogSignalTransportType = 1
    CallProgressTonesFilename = 'usa_tones_12.dat'
    [WEB Params]
    LogoWidth = '339'
    [SIP Params]
    ENABLECALLERID = 1
    MAXDIGITS = 10
    ALWAYSUSEROUTETABLE = 0
    PLAYRBTONE2IP = 1
    REGISTRATIONTIME = 3600
    USERADLOG = 1
    ISPROXYUSED = 0
    ISREGISTERNEEDED = 1
    AUTHENTICATIONMODE = 0
    ISWAITFORDIALTONE = 1
    ISTWOSTAGEDIAL = 0
    ENABLECURRENTDISCONNECT = 1
    RADDEBLEVEL = 2
    MAXACTIVECALLS = 4
    CHANNELSELECTMODE = 2
    RADLOGOUTPUT = 1
    GWDEBUGLEVEL = 6
    ENABLEPROXYKEEPALIVE = 0
    ENABLERPIHEADER = 1
    ENABLEEARLYMEDIA = 1
    DEFAULTNUMBER = '101'
    PROXYNAME = '3cx'
    REGISTRARIP = '192.168.80.11'
    SIPGATEWAYNAME = '192.168.80.15'
    USERNAME = ''
    CNONCE = '0a123bcf'
    PASSWORD = ''
    ISFALLBACKUSED = 0
    ALWAYSSENDTOPROXY = 1
    ISPROXYHOTSWAP = 0
    PROXYKEEPALIVETIME = 60
    PROXYREDUNDANCYMODE = 0
    PROXYHOTSWAPRTX = 3
    SENDINVITETOPROXY = 1
    REGISTRATIONRETRYTIME = 30
    USEGATEWAYNAMEFOROPTIONS = 0
    ADDTON2RPI = 0
    PREFERROUTETABLE = 0
    USESOURCENUMBERASDISPLAYNAME = 1
    SUBSCRIPTIONMODE = 1
    GWREGISTRATIONNAME = '192.168.80.15'
    REGISTRARNAME = '192.168.80.11'
    REGISTRATIONTIMEDIVIDER = 50
    RINGSBEFORECALLERID = 2
    REMOTEBASEUDPPORT = 0
    COMFORTNOISENEGOTIATION = 1
    CODERNAME = g711Ulaw64k,20,0,0,0
    CALLERDISPLAYINFO7 = Front Door,0
    PREFIX = *,192.168.80.11,*,1,255
    PSTNPREFIX = *,1,*,*,0
    TARGETOFCHANNEL4 = 999,0
    TARGETOFCHANNEL5 = 999,0
    TARGETOFCHANNEL6 = 999,0
    TARGETOFCHANNEL7 = 998,1
    TARGETOFCHANNEL0 = 10000,1
    TARGETOFCHANNEL1 = 10001,1
    TARGETOFCHANNEL2 = 10002,1
    TARGETOFCHANNEL3 = 10003,1
    TRUNKGROUP_1 = 1-1,10000,0
    TRUNKGROUP_1 = 2-2,10001,0
    TRUNKGROUP_1 = 3-3,10002,0
    TRUNKGROUP_1 = 4-4,10003,0
    PROXYIP = 192.168.80.11
    AUTHENTICATION_0 = 10000,10000
    AUTHENTICATION_1 = 10001,10001
    AUTHENTICATION_2 = 10002,10002
    AUTHENTICATION_3 = 10003,10003
    TRUNKGROUPSETTINGS = 1,1,0,$$
    TXDTMFOPTION = 4
    ;TelProfile: ProfileName, Preference, CodersGroupID, IsFaxUsed, DJBufMinDelay, JBufOptFactor, IPDiffServ, SigIPDiffServ, DtmfVolume, InputGain, VoiceVolume, EnableReversePolarity, EnableCurrentDisconnect, EnableDigitDelivery, ECE, MWIAnalog, MWIDisplay, FlashHookPeriod, EnableEarlyMedia, ProgressIndicator2IP
    TELPROFILE_1 = Default Tel Profile,1,0,0,10,10,46,40,-6,-6,10,0,1,0,1,0,0,400,1,-1
    ENABLECALLERID_0 = 1
    ENABLECALLERID_1 = 1
    ENABLECALLERID_2 = 1
    ENABLECALLERID_3 = 1
    ENABLECALLERID_4 = 1
    ENABLECALLERID_5 = 1
    ENABLECALLERID_6 = 1
    ENABLECALLERID_7 = 1
    [VXML Params]
    [IPsec Params]
    [Audio Staging Params]
    DisableSNMP = 1
    ; *** TABLE DspTemplates ***
    ; This table contains hidden elements and will not be exposed.
    ; This table exists on board and will be saved during restarts
  7. brianfpmoab
    Mar 15, 2007
    17
    Mike,
    Here is my ini file.
    ;** Ini File **
    ;Board: MP-118 FXO
    ;Serial Number: 710115
    ;Slot Number: 1
    ;Software Version: 4.80A.014.006
    ;Board IP Address: xx.xx.xx.131
    ;Board Subnet Mask: 255.255.255.128
    ;Board Default Gateway: xx.xx.xx.129
    ;Profile: NONE
    [SYSTEM Params]
    DisableSNMP = 1
    DNSPriServerIP = xx.xx.x.2
    SyslogServerIP = 10.1.1.89
    VoiceMenuPassword = 'disable'
    [BSP Params]
    PCMLawSelect = 3
    LocalOAMIPAddress = xx.xx.xx.131
    [ATM Params]
    [Analog Params]
    [MGCP Params]
    [MEGACO Params]
    EP_Num_0 = 0
    EP_Num_1 = 1
    EP_Num_2 = 0
    EP_Num_3 = 0
    EP_Num_4 = 0
    [SS7 Params]
    IdlePCMPattern = 85
    EnableSilenceCompression = 1
    VoiceVolume = 1
    [WEB Params]
    LogoWidth = '339'
    [SIP Params]
    ENABLECALLERID = 1
    MAXDIGITS = 10
    TIMEBETWEENDIGITS = 6
    USERADLOG = 1
    ISPROXYUSED = 1
    ISTWOSTAGEDIAL = 0
    ENABLEHOLD = 0
    RADDEBLEVEL = 2
    RADLOGOUTPUT = 1
    GWDEBUGLEVEL = 6
    PROXYNAME = 'xx.xx.xx.138'
    REGISTRARIP = 'xx.xx.xx.138'
    SIPGATEWAYNAME = 'Moab'
    GWREGISTRATIONNAME = 'Moab'
    REGISTRARNAME = 'xx.xx.xx.138'
    RINGSBEFORECALLERID = 0
    CODERNAME = g711Ulaw64k,20,0,$$,0
    CODERNAME = g711Alaw64k,20,0,$$,0
    CODERNAME = g7231,30,0,$$,0
    CODERNAME_1 = g711Ulaw64k,20,0,$$,0
    CODERNAME_1 = g711Alaw64k,20,0,$$,0
    CODERNAME_1 = g729,20,0,$$,0
    CALLERDISPLAYINFO0 = HOTNC,0
    CALLERDISPLAYINFO1 = HOTNC,0
    CALLERDISPLAYINFO2 = HOTNC,0
    CALLERDISPLAYINFO3 = HOTNC,0
    CALLERDISPLAYINFO4 = HOTNC,0
    PREFIX = *,xx.xx.xx.138,*,1,255
    PSTNPREFIX = *,1,*,*,1
    PSTNPREFIX = *,2,*,*,1
    TARGETOFCHANNEL0 = 4352594857,1
    TARGETOFCHANNEL1 = 4352594019,1
    TARGETOFCHANNEL2 = 4352596677,1
    TARGETOFCHANNEL4 = 4352598168,1
    TARGETOFCHANNEL3 = 4352594384,1
    TRUNKGROUP_1 = 5-5,10004,0
    PROXYIP = xx.xx.xx.138
    AUTHENTICATION_0 = 4352594857,4352594857
    AUTHENTICATION_1 = 4352594019,4352594019
    AUTHENTICATION_2 = 4352596677,4352596677
    AUTHENTICATION_4 = 4352598168,4352598168
    AUTHENTICATION_3 = 4352594384,4352594384
    TRUNKGROUPSETTINGS = 1,3
    TRUNKGROUPSETTINGS = 2,1
    [VXML Params]
    [IPsec Params]
    [PSTN-SDH Params]
    Brian
  8. Anonymous
    Anonymous Guest
    With these configs, would there be a need to have this consolidated under a similar section as or the VOIP providers?
    H.
