Can't make outbound calls in V5
Discussion in '3CX Phone System - General' started by richie314nj, Jan 7, 2008.
  1. richie314nj
    Jun 22, 2007
    19
    I can no longer make outgoing calls using V5
    VOIP Provider: Broadvoice
    IP phone: Grandstream 2000
    I used the template to setup Broadvoice
    I had no problems using v3.1
    log:
    19:30:08.250 Call::Terminate [CM503008]: Call(21): Call is terminated
    19:29:59.750 CallCtrl::eek:nLegConnected [CM503007]: Call(21): Device joined: sip:9738331973@sip.broadvoice.com:5060
    19:29:59.734 CallCtrl::eek:nLegConnected [CM503007]: Call(21): Device joined: sip:102@192.168.50.107:5060;transport=udp;user=phone
    19:29:59.625 Line::printEndpointInfo [CM505003]: Provider:[Broadvoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.50.2:5060]
    19:29:58.984 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(21): Calling: VoIPline:10000@[Dev:sip:9738331973@sip.broadvoice.com:5060, Dev:sip:9738331973@sip.broadvoice.com:5060]
    19:29:58.906 CallCtrl::eek:nIncomingCall [CM503001]: Call(21): Incoming call from Ext.102 to [sip:819738682237@192.168.50.2;user=phone]
    19:21:43.984 ExtnCfg::updateContact [CM504001]: Ext.102: new contact is registered. Contact(s): [sip:102@192.168.50.107:5060;transport=udp;user=phone/102]
    19:18:50.921 Call::Terminate [CM503008]: Call(20): Call is terminated
    19:18:43.671 CallCtrl::eek:nLegConnected [CM503007]: Call(20): Device joined: sip:9738331973@sip.broadvoice.com:5060
    19:18:43.656 CallCtrl::eek:nLegConnected [CM503007]: Call(20): Device joined: sip:102@192.168.50.107:5060;transport=udp;user=phone
    19:18:43.531 Line::printEndpointInfo [CM505003]: Provider:[Broadvoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.50.2:5060]
    19:18:42.890 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(20): Calling: VoIPline:10000@[Dev:sip:9738331973@sip.broadvoice.com:5060, Dev:sip:9738331973@sip.broadvoice.com:5060]
    19:18:42.812 CallCtrl::eek:nIncomingCall [CM503001]: Call(20): Incoming call from Ext.102 to [sip:819738682237@192.168.50.2;user=phone]
    19:18:06.046 Call::Terminate [CM503008]: Call(19): Call is terminated
    19:18:01.843 CallCtrl::eek:nLegConnected [CM503007]: Call(19): Device joined: sip:9738331973@sip.broadvoice.com:5060
    19:18:01.828 CallCtrl::eek:nLegConnected [CM503007]: Call(19): Device joined: sip:102@192.168.50.107:5060;transport=udp;user=phone
    19:18:01.781 Line::printEndpointInfo [CM505003]: Provider:[Broadvoice] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.50.2:5060]
    19:18:01.156 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(19): Calling: VoIPline:10000@[Dev:sip:9738331973@sip.broadvoice.com:5060, Dev:sip:9738331973@sip.broadvoice.com:5060]
    19:18:01.078 CallCtrl::eek:nIncomingCall [CM503001]: Call(19): Incoming call from Ext.102 to [sip:819738682237@192.168.50.2;user=phone]
    19:16:44.000 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:888@192.168.50.2:5100;user=phone
    19:16:43.671 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    19:16:23.265 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.50.2:5060
  2. simones181170
    Dec 4, 2007
    51
    after the upgrade of v3 to v5 u have to delete and write again the Outbound Rules
  3. richie314nj
    Jun 22, 2007
    19
    I took it a step further.
    I did a fresh install of V5 on another computer and I get the same results.
  4. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    i am having the same problem, the inbound calls work ok
    regards
  5. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    I think whats happening is your remote extension is initiating a call and broadvoice tries to respond, but because you using a non-routeable private IP (192.168.50.2) it hangs up. Your remote extension should be initiating that request with the NAT firewalls public IP and not your private non-routable IP. STUN would keep the NAT Firewalls port open so when Broadvoice tried to respond it would be successful.
  6. richie314nj
    Jun 22, 2007
    19
    I'm lost.
    :?: Where would I go in 3XC to correct this?
    v3 worked so well the 1st time out. What happened in V5? :(
  7. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    richie314nj,
    Comparing 2 lines from your failed call log and 2 lines of mine on a successful call out on Broadvoice I believe the issue is your remote extension 102 is sending out its private ip. In my log my ext 505 has a private IP of 192.168.0.44, but using STUN and a feature in my voip ata It uses the IP address of my NAT,76.184.178.165.
    Since SIP uses TCP/IP as its transport and devices are talking point-to-point then it stands to reason that broadvoices public ip can not talk to your private IP.
    You need to look at your remote extension voip settings for something that says use NAT address for IP. I have a Linksys PAP2 that has that and I used to use a Grandstream 386 that also had that feature.
    I would look there to see if you can't fix this.
    ---- your log ----
    -----mine log
    09:00:01.236 CallCtrl::eek:nLegConnected :[CM503007]: Call(56): Device joined: sip:9722262972@sip.broadvoice.com:5060
    09:00:01.221 CallCtrl::eek:nLegConnected :[CM503007]: Call(56): Device joined: sip:505@76.184.178.165:13837
  8. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    webguyz, sorry, but you confuse richie314nj with completely wrong information.
    First, PBX is using UDP protocol as preferred, although it supports TCP/IP either. But in any case, all calls are proxied by PBX, so there's no direct communication between phone and provider.
    Second, I see no message regarding successful resolution of external IP:port mapping. Probably, it's just skipped, but we have to be sure that external mapping has been resolved by STUN client.
    Third, according to logs all is ok, beside STUN resolution. The only thing I can not understand is this line:
    Actually, there should be only one [Dev:... ] in square brackets.
    Fourth, it seems broadvoice terminates connection after call has been established. Most probable reason for this is absence of common codec. Make sure you have enabled codecs for that providers. I do not remember which codecs it supports, but at least make sure that G711 and GSM are available. And, just in case, check your balance at broadvoice :)
  9. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Thanks for the clarification. :oops:
  10. archie
    3CX Support
    Aug 18, 2006
    1,299
    Welcome :)
    Just some afterthoughts.
    Actually, call has been established. It means that broadvoice had been able to talk back to PBX, so Contact is duly. But after that broadvoice has dropped a call. Most probably it is a codecs issue.
  11. richie314nj
    Jun 22, 2007
    19
    Thank you for the information.
    I will look at the settings again and check the codecs.
    I'll let you all know how I make out.
  12. richie314nj
    Jun 22, 2007
    19
    Thanks you all for your help.
    I've downloaded the updated Broadvoice template, deleted the account, recreated the account using the newly download template, and I used teh same exact settings as I had did before. Now I'm able to make outgoing calls via Broadvoice.
    I believe there may have been a bug in the original template in V5.
    Once again thank you for all your input.
  13. Jared.Savage
    Nov 28, 2007
    7
    I'm also having this problem, and cannot make any outgoing calls with v5.1!
    The error line in my setup contains Many instances of "Dev:sip" within the brackets. A bug with a string being appended and not replaced?
    [CM503004]: Call(32): Calling: VoIPline:10000@[Dev:sip:eek:urusername@sip.voicemeup.com:5060, Dev:sip:eek:urusername@sip.voicemeup.com:5060, Dev:sip:eek:urusername@sip.voicemeup.com:5060, Dev:sip:eek:urusername@sip.voicemeup.com:5060, Dev:sip:eek:urusername@sip.voicemeup.com:5060]
  14. frankiej
    Mar 16, 2008
    I've got a problem like ts has; look at my report:
    The server log shows server activity and detailed logging Messages. More > These log messages can allow you to troubleshoot firewall, VOIP gateway, VOIP provider and SIP phone configuration issues. When requesting support, always post the relevant server status logs for a particular issue. < Less
    Time Function Message
    22:37:56.859 Call::Terminate [CM503008]: Call(10): Call is terminated
    22:37:56.843 Call::RouteFailed [CM503014]: Call(10): Attempt to reach [sip:041864xxxx@82.95.1xx.xx:5060] failed. Reason: Temporarily Unavailable
    22:37:56.843 CallLeg::eek:nFailure [CM503003]: Call(10): Call to sip:041864xxxx@sip.xs4all.nl:5060 has failed; Cause: 480 Temporarily Not Available; from IP:82.101.62.99:5060
    22:37:51.312 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:88@3CXPhoneSystem with contact sip:88@82.95.1xx.xx:5100;user=phone
    22:37:50.421 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:88:5100;user=phone
    22:37:22.437 Line::printEndpointInfo [CM505003]: Provider:[xs4all1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:82.95.1xx.xx:5060]
    22:37:22.109 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(10): Calling: VoIPline:10000@[Dev:sip:0878759xxx@sip.xs4all.nl:5060]
    22:37:22.093 CallCtrl::eek:nIncomingCall [CM503001]: Call(10): Incoming call from Ext.10 to [sip:041864xxxx@82.95.1xx.xx:5060]
    What's wrong here?
  15. h2009
    h2009 Member
    Mar 15, 2008
    447
    Are you stun servers working correctly? ( i had this problem either today, and found the stun server ports (some of them were getting blocked/port in usage message)
    Have you got the correct settings in your outbound call manager?
    Have you got credit on your account?
  16. Halea
    Halea New Member
    Jan 5, 2008
    151
    Check to see if you have STUN activated and an outgoing proxy server defined simultaneously. Some providers don't properly handle the outgoing call when these two things are both active.
    Halea
  17. frankiej
    Mar 16, 2008
    where and which (stun)ports do I have to change? The outside IP has been mapped to the 3cx server.
    I think the settings are correct because registering is ok
    look at my other posting
