Can't make outgoing calls from CISCO ATA 186
Discussion in '3CX Phone System - General' started by maxbn, Dec 16, 2008.
  1. maxbn
    Dec 16, 2008
    I try to use 3cx system version 7 with cisco ATA 186 with SIP firmware ATA030201SIP050616A.zup. I can see ATA status regestered and get incoming calls. Moreover, I can call to another extension (such as the 7912 Cisco phone) but any other outgoing call terminated with authorization error:
    16:09:44.681 [CM502001]: Source info: From: "ATA_Port0"<sip:6002@10.10.20.45:5061;user=phone>;tag=3845434265<sip:9264542@10.10.20.45;user=phone>
    16:09:44.681 [CM503013]: Call(306): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 9264542@10.10.20.45 tid=7a4da474ed51c739 cseq=INVITE contact=6002@10.10.10.50:5061 / 2 from(wire)
    16:09:44.681 [CM500002]: Info on incoming INVITE:
    INVITE sip:9264542@10.10.20.45;user=phone SIP/2.0
    Via: SIP/2.0/UDP 10.10.10.50:5061;branch=z9hG4bK7a4da474ed51c739
    Contact: "ATA_Port0"<sip:6002@10.10.10.50:5061;user=phone;transport=udp>
    To: <sip:9264542@10.10.20.45;user=phone>
    Call-ID: 2741561524@192.168.25.4
    CSeq: 2 INVITE
    Expires: 300
    Allow: ACK, BYE, CANCEL, INVITE, NOTIFY, OPTIONS, REFER, REGISTER, PRACK, UPDATE
    Proxy-Authorization: Digest username="6002",realm="3CXPhoneSystem",nonce="12873906584:3b811dc85f17e572897fccaf14c43a19",uri="sip:9264542@10.10.20.45",response="ed784130756f1d3040a67ca0e04dd9ce"
    Supported: 100rel, replaces
    User-Agent: Cisco ATA 186 v3.2.1 atasip (050616A)
    Content-Length: 0
    16:09:44.494 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 10.10.10.50:5061;branch=z9hG4bK74581ed31bd2688b
    CSeq: 1 INVITE
    Expires: 300
    Content-Length: 0
    16:09:44.494 [CM302001]: Authorization system can not identify source of: SipReq: INVITE 9264542@10.10.20.45 tid=74581ed31bd2688b cseq=INVITE contact=6002@10.10.10.50:5061 / 1 from(wire)
    Do anyone have any ideas what's the problem?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,913
    221
    I suggest using an ATA that is supported and much easier to setup, for example Grandstream or Linksys ATA's...
