Can't make simultanusly 2 calls
Discussion in '3CX Phone System - General' started by kousinovaliskostas, Aug 23, 2016.
  1. kousinovaliskostas
    Aug 17, 2016
    6
    Hello
    Today I noticed that i can't make 2 simultanusly calls which is worked some days ago.
    The log says
    Leg L:45.3[Line:10000>>6936158137] is terminated: Cause: 503 Service Unavailable/INVITE from 192.168.1.160:5060
    192.168.1.160 is the 3cx PC
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,551
    298
    Gateway with PSTN, Gateway with ISDN, VoIP/SIP Service?
  3. kousinovaliskostas
    Aug 17, 2016
    6
    We have ISDN line and we use the grandstream gxw4104
  4. kousinovaliskostas
    Aug 17, 2016
    6
    grandstream gxw4104
  5. leejor
    11,084
    325
    Sounds like a gateway, or provider issue. Are you able to place a call, and still receive one over ISDN?
