Can't play call recordings
Discussion in '3CX Phone System - General' started by IA76, Nov 13, 2013.
  1. IA76
    Mar 31, 2011
    24
    When I try and play call call reportings from the call reporting section I get this error below when I click on play, however I can play recordings for my extension.
    You have no rights to load: c:\programdata\3cx\data\recordings\349\[mr x]_349-00966500872106_20131021183742(7).wav
    Please contact administrator.
    Under options-access all boxes are ticked and also under rights I am set as manager.
    Error log is showing this
    2013/11/13 22:53:36.110|Inf(03)| Loading data for Report: Call Logs
    2013/11/13 22:53:36.196|Inf(03)| Executing Call Logs Report Function: SELECT * from CallFlow_Report(' starttime >= ''2013-10-13 22:53:33'' AND starttime <= ''2013-11-13 22:53:33''', 'http://localhost:5000/Reports/RecordsHandler.aspx?file=')
    2013/11/13 22:53:48.848|Err(01)| User 200 has no rights for: c:\programdata\3cx\data\recordings\349\[mr x]_349-00966500872106_20131021183742(7).wav
    2013/11/13 22:54:44.546|Err(01)| User 200 has no rights for: c:\programdata\3cx\data\recordings\349\[mr x]_349-00966500872106_20131021183742(7).wav
  2. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Hi IA76,
    for the current released version you cannot see other extensions' recordings unless you log into web reports with the administrator credentials. This is coming in the next service pack so please be patient for while longer. If you have any further questions or inquiries feel free to let me know.
    Best Regards
