Can't play wav. file
Discussion in '3CX Phone System - General' started by KenC, Apr 28, 2012.
  1. KenC
    Mar 29, 2012
    85
    I'm getting an error from a recorded "on hold" file:
    Thanks!
    11,293
    361
    If you use Windows Explorer, and try to open the file, to play it, do you get an error message, or does it play correctly?
  3. clonick
    Apr 19, 2012
    26
    I think you can't play the file for right permissions or because is using by the pbx file, for it reason says -stream source-
    first of all you need to play the file in windows to know if you are capable of ear it, but for stay sure, try to stop all the services of 3cx before you play the file.
    you can go to start - run and write: services.msc
    then, stop all the services of 3cx
    then, go to the golder where is the wav file and try to open with windows media player. if it souns or not, come to this forum and reply Us.
    then, start all the services of 3cx again.
  4. KenC
    Mar 29, 2012
    85
    plays fine wih windows player even without stopping 3cx services.
  5. leejor
    11,293
    361
    Did you record it using the correct format?
    http://www.net-point.ch/blog/3cx-wave-file-format-wav-fur-audio-recordings/
  6. KenC
    Mar 29, 2012
    85
    Are there more than one .wav formats?
  7. KenC
    Mar 29, 2012
    85
    is there a max acceptible size of .wav file?
  8. leejor
    11,293
    361
    Yes, apparently there are...http://en.wikipedia.org/wiki/WAV
    There may be. You might want to start with a smaller file size and work up
