Can't provision 3CX Phone for Windows v6.0 with 3CX Assist.
Discussion in 'Windows' started by RobKasbow, May 6, 2011.
  1. RobKasbow
    Nov 21, 2010
    21
    When I download the new version of the 3CX phone for Windows 7, it does not link up with 3CX Assistant. I tried reloading 3CX Assistant with integration to the 3CX Phone for Windows 7, but it reverts back to the old version of the 3CX Phone for Windows. What am I doing wrong here?
    Rob
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    68
    Re: Can't provision 3CX Phone for Windows v6.0 with 3CX Assi
    Hi Rob
    You're doing nothing wrong - 3CXPhone vers 6 is "ver 6" only as standalone version. 3CXPhone ver 6 is not supposed to be integrated with Assistant, due to the new design/features provided by the 3CXPhoneSystem v.10 package.
    However, an "unsupported solution" to your problem is:
    - without Assistant installed, install 3CXPhone v6
    - copy somewhere its whole binary folder, C:\Program Files\3CXPhone
    - uninstall 3CXPhone v6
    - install Assistant with its "embedded" 3CXPhone v5
    - overwrite Asssistant's phone binaries folder with the one you saved earlier.
    Hope it helps
    Regards
    vali
