Can't provisioning ring groups as a speed dial destination.
Discussion in '3CX Phone System - General' started by cobaltit, Jun 8, 2013.
  1. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,620
    243
    Provisioning a speed dial to a ring group is not possible via the provisioning tab, only extensions are selectable. I think we went over this at the training in Seattle and Kevin decided that was probably a bug. Same in v11.
    Before someone says something smart, yes you can enter it in as a Custom Speed Dial.
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Re: Can't provisioning ring groups as a speed dial destinati
    @cobaltit
    I will look into this, but for future reference, the correct place to push for such improvements is via the Feature Requests page here:
    https://apps.facebook.com/threecxideas/
