Can't push company phone book from 3CX server.
Discussion in '3CX Phone System - General' started by Divyesh, Apr 21, 2017.
  1. Divyesh
    Apr 21, 2017
    20
    Hi, I'm running 3CX inhouse (v12.0.4) alongside SNOM 821 phones (latest F/W). The problem I have is, I can't manage the SNOM phone book via 3CX management console. I have to go to each phone with a .csv file and update it manually. Is there a way of using the company phone book to push out contacts to all phones upon provisioning? I don't want to use AD/LDAP for now.
    Thank you!
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Divyesh
    Do the phones provision correctly? The PBX phonebook should push to the phone while you provision the phones. The phonebook provisioning is done through Http.
  3. Divyesh
    Apr 21, 2017
    20
    Hi Yiannish, I'm new to 3CX. By provisioning, if I were to reset the phone, it gets the PBX ip add, and I can log in without doing anything else other than setting the timezone and language. I've tried to edit the phone provisioning template but to no avail.
  4. saqqara16
    Jan 13, 2016
    45
    7
  5. Divyesh
    Apr 21, 2017
    20
    Thanks for your reply Saqqara, I've followed that guide but I still can't get the company phone book on Snom phones.
  6. Divyesh
    Apr 21, 2017
    20
  7. YiannisH_3CX
    May 10, 2016
    6,016
    421
    This might be a firmware issue as the latest firmware was never tested with version 12. I am not sure what firmware was supported for v12 but if i were you i would try downgrading the phone to a previous version to see if that works for you.
  8. Divyesh
    Apr 21, 2017
    20
    I've just tried that and it still doesn't work. In 3CX -> Phones - management console I get the correct MAC address and the date/time is updated.
    I've tried another model - Snom 870 still to no avail. All phones have been factory reset, I can see that the date and time is updated when I provision them but that's all, I need a company-wide phone book working on these handsets. Any help?
  9. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Since you are on an older version of 3CX which is no longer supported i would recommend upgrading to the latest V15 version to see if your issue is fixed there. Since your phones are supported you shouldn't have any issues getting the phonebook to work
    Divyesh likes this.
  10. Divyesh
    Apr 21, 2017
    20
    Thank you for that, I've got 1 more question about upgrading. If I don't want to save my data, can I uninstall v12 and do a fresh install of v15? Or do I still have to go to v12.5 then to v15?
    Thanks in advance.
  11. YiannisH_3CX
    May 10, 2016
    6,016
    421
    You need to go to 12,5 and then to V15. You can only skip one major version when upgrading. Make sure that there are no service packs pending for v12 before upgrading
    Divyesh likes this.
