Can't Receive call on external spa 942
maxime
All port is open when sombedy call it ring but the line cut when i pick up the phone and i dont have voice when i call the vmail extention
Try enabling NAT Mapping under the EXT tab.
it dont want ton register with nat
stun is enable
all audio on pbx is disable
i can call on a landline or cellphone but call cut when i pick up the phone and no audio when i call the vmail extension
what is the network setup on both ends?
also, make sure that you have a correct value retrieved for "External IP" on the default "INFO" tab. If you do not, verify that the machine has the correct DNS information. I had the most luck using DHCP for this.
dmz on both side
Did you set the option "PBX delivers Audio" for that extension?
3CX will else hand-off the call to the other party, being an internal phone, a gateway or VOIP provider (i.e. let the two communicate directly instead of through 3CX).
Get 3CX - Absolutely Free!
3CX
