Can't receive incoming calls
Discussion in '3CX Phone System - General' started by abinns, Apr 10, 2007.
  1. abinns
    Apr 10, 2007
    I have 6 PSTN lines coming into a Grandstream GXW-4108. I can call out on the lines, transfer, conference, etc. Whenever I call any of the phone numbers, I get this debug info:
    Endpoint::findSource Can not find source by following specs: From: 'unknown'; To: '10000'; Rline: '10000'; Contact: '10000'
    I've tried forwarding all numbers to extension 100, I've also tried having them forward to a ring group with extension 150 (which encompasses 8 extensions). None of this has helped (and I doubted that it would have!). I've read one post that explains a little about it (http://www.3cx.com/forums/viewtopic.php?t=1035), but I still couldn't quite understand it.
    I have set up and registered all 6 lines with internal extensions of 10000-10005.
    What am I ding wrong? Thanks!
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Check the advanced configuration for the grandstream from the management console. Go to "Lines/Manage/click on the name of your gateway not the number/Show advanced options. Make sure that "Line-ID location in 'user' part of:" is in "To" field instead of "from".
    And "Line-ID matching:" is in external
    let me know if this solved the problem. Remember what the initial conf was in case this doesn't work to return to default state.
  3. abinns
    Apr 10, 2007
    Didn't seem to work
    Hi, that didn't seem to do the trick. I still come up with the same error msg in the Server Status screen.
    -Andrew
  4. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Re: Didn't seem to work
    Sorry, Line-ID matching should be 'Internal number'
