can't receive incoming calls
Discussion in '3CX Phone System - General' started by guyla50, Feb 8, 2010.
  1. guyla50
    Oct 6, 2008
    7
    Hi guys,
    I'm not sure this is a 3cx issue, but I'm a little stuck. I am using sipgate as a sip provider, I can make outbound calls ok, the firewall test passes ok.
    However when i try inbound calls it doesn't work. If I log onto sipgate it says my "device" is offline. This isn't true as I can dial out perfectly.
    Any help on how to fix this would be massively appreciated it's driving me nuts...
    Guy
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Edit the voip provider information, you probably need to check the box for registration is required for inbound calls.
