Can't recieve audio during live call
Discussion in 'Windows' started by kd0jzi, Feb 27, 2010.
  1. kd0jzi
    Feb 27, 2010
    7
    I am having problems with not being able to hear anyone when I make or receive a call.
    They can hear me just fine.
    I can also hear my voice mails just fine.
    Any ideas???
  2. bilalamjad3
    Feb 6, 2010
    6
    so what problem.
  3. leejor
    11,129
    330
    Are you using the phone on the same LAN or remotely? Can't hear other extensions and/or external calls?
  4. kd0jzi
    Feb 27, 2010
    7
    Remotely, can't hear extensions.
    I've tried port forwarding the router, shutting down firewalls, turning off nat. And still only one way audio.
    Thanks for the reply.
  5. leejor
    11,129
    330
    If you are using it remotely, try the tunnel option, see if that helps. One way audio is almost always a blocked or miss-directed port problem. If you, at the remote end, are not hearing audio, then that would point to an issue with the router/firewall at that end. Try bypassing the router, get a public IP on the PC running the 3Cx softphone, see if you get audio. Have you tried from more than one remote location (router)?
  6. mfm
    mfm Active Member
    Mar 4, 2010
    641
    In situations like these, primarily the cause is the the external IP fails to resolve for whatever reason therefore the audio gets routed to an incorrect destination.
    1. Run the firewall checker on the PBX Side, post results
    2. Make sure you have set stun to stun.3cx.com
    3. Try using tunnel and advise outcome.
