Can't recieve call to 3CXPhone for windows
Discussion in '3CX Phone System - General' started by KOUSIS, Nov 18, 2017.
  1. KOUSIS
    Nov 17, 2010
    26
    Hello
    I've installed the program with the id 300 and i've register to 3xc system.
    I can make calls from the program to any number.
    The problem is that i cant call the specific extension, its always comes up to leave a message.
    The program says Available.
    Any help?
    Thank you
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    872
    133
    I would send the welcome email and click on the attachment which has the config for extension
    Also if the pc on the same lan as the 3cx pc
  3. KOUSIS
    Nov 17, 2010
    26
    And how do you send the welcome email?
  4. KOUSIS
    Nov 17, 2010
    26
    I am using version 11 by the way
  5. leejor
    10,365
    227
    Is this a new extension?
    Is it in the same location as other extensions? Remote, or local to the server?
    If it is remote, is it behind an SBC or just a router?
    If just behind a router, it must have a local port that is unique to the device, you can't have two remote devices, behind the same router (no SBC), that use the same (5060?) local port number.
  6. KOUSIS
    Nov 17, 2010
    26
    Yes it's a new extension.
    It's in the local network.
    It have the ip 192.168.1.2 and the other extensions have ...231 ....232 etc.
    As I told I can make calls successful from this extension but I can't receive calls.
    I also tried to disable the firewall or open exclusively the port but with no luck.
  7. leejor
    10,365
    227
    It shouldn't be a firewall issue if it is on the same LAN as the server. It may be an IP or port issue. Check the 3CX Activity log right after a call to the extension. Does the IP and port appear to be what you think it should be. What about right after a registration attempt? Does the extension even show as registered in 3CX.
    Either 3CX can't send an Invite to the destination it has been told that the extension resides, or you may have an option, such as Do Not Disturb Not Available, active. The log should give you some information as to why the call cannot be completed.
  8. KOUSIS
    Nov 17, 2010
    26
    These are the logs.
    The 3cxPhone has the extenstion 300 and the IP is 192.168.1.2
    The server has the IP 192.168.1.200
    20-Νοε-2017 09:26:50.125 Leg L:8.2[Extn:300] is terminated: Cause: 408 Request Timeout/INVITE from local
    20-Νοε-2017 09:26:50.125 [CM503003]: Call(C:8): Call to <sip:300@192.168.1.200:5060> has failed; Cause: 408 Request Timeout/INVITE from local
    20-Νοε-2017 09:26:43.703 Leg L:8.3[VMail:999] is terminated: Cause: BYE from PBX
    20-Νοε-2017 09:26:43.703 [CM503008]: Call(C:8): Call is terminated
    20-Νοε-2017 09:26:43.703 Leg L:8.1[Extn:203] is terminated: Cause: BYE from 192.168.1.233:5062
    20-Νοε-2017 09:26:38.296 [CM503007]: Call(C:8): VMail:999 has joined, contact <sip:999@127.0.0.1:40600>
    20-Νοε-2017 09:26:38.296 [CM503007]: Call(C:8): Extn:203 has joined, contact <sip:203@192.168.1.233:5062>
    20-Νοε-2017 09:26:38.296 L:8.3[VMail:999] has joined to L:8.1[Extn:203]
    20-Νοε-2017 09:26:38.109 [CM503025]: Call(C:8): Calling T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=aedfbaaf180e023b] for L:8.1[Extn:203]
    20-Νοε-2017 09:26:38.062 [CM503005]: Call(C:8): Forwarding: T:VMail:999@[Dev:sip:999@127.0.0.1:40600;rinstance=aedfbaaf180e023b]
    20-Νοε-2017 09:26:38.062 L:8.1[Extn:203] forwards call from Extn:300 to VMail:999 based on rule Fwd[Available/NoAnsw]
    20-Νοε-2017 09:26:38.062 L:8.1[Extn:203] failed to reach Extn:300, reason No Answer
    20-Νοε-2017 09:26:35.968 Currently active calls - 2: [6,8]
    20-Νοε-2017 09:26:18.031 [CM503025]: Call(C:8): Calling T:Extn:300@[Dev:sip:300@192.168.0.2:62343;rinstance=cc89892596a35980] for L:8.1[Extn:203]
    20-Νοε-2017 09:26:17.984 [CM503027]: Call(C:8): From: Extn:203 ("Kostas" <sip:203@192.168.1.200:5060>) to T:Extn:300@[Dev:sip:300@192.168.0.2:62343;rinstance=cc89892596a35980]
    20-Νοε-2017 09:26:17.984 [CM503004]: Call(C:8): Route 1: from L:8.1[Extn:203] to T:Extn:300@[Dev:sip:300@192.168.0.2:62343;rinstance=cc89892596a35980]
    20-Νοε-2017 09:26:17.984 [CM503001]: Call(C:8): Incoming call from Extn:203 to <sip:300@192.168.1.200:5060>
  9. leejor
    10,365
    227
    It would appear that the call rang ext 300 for about 10 seconds, then went to voicemail as programmed as it was not answered. Do you need to, perhaps, increase the call forward timeout? Is the set not indicating an incoming call?
    Not certain about the port used by the set...62343, and why it isn't something like 5060.
  10. Schrodz
    Apr 21, 2017
    91
    9
    Version 11?!??!?!?
