- Joined
- Sep 6, 2011
- Messages
- 3
- Reaction score
- 0
Hello, I am new to this whole SIP/PBX thing and hope I can get some help here. Here is my information,
I just got my service from Via Talk and CAN connect/call/receive through a SIP Phone (X-Lite) just fine. I am running the 3cx system on a dedicated server I own, The firewall is OFF and the router is a linksys, I have forwarded all the ports needed (I run game servers/voips off of the box as well) so I know it is set correctly. I have provisioned my Polycom 501 (SoundPoint IP 501) with PBX and they ARE connected.
3cx shows that my Trunk is Registered(idle) & my extensions shows up Registered(idle) and when I call voicemail even though it's not connected to my Via Talk Voicemail for some reason? I do see it go yellow and say "Connected" in 3cx.
My problem is that I cannot make calls nor receive them, If say I call out it says "Called Number Does Not Exist" (I set something up in 3cx so it says an error and doesn't just give me a busy signal like it was going)
Error Log for calling out:
18:52:06.633 [CM503008]: Call(7): Call is terminated
18:52:01.428 [CM503007]: Call(7): Device joined: sip:[email protected]:40600;rinstance=2a252158b4e19f26
18:52:01.424 [CM503007]: Call(7): Device joined: sip:[email protected]:5060
18:52:01.419 [CM503002]: Call(7): Alerting sip:[email protected]:40600;rinstance=2a252158b4e19f26
18:52:01.271 [CM503025]: Call(7): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=2a252158b4e19f26]
18:52:01.227 [CM503016]: Call(7): Attempt to reach <sip[email protected];user=phone> failed. Reason: Not Found
18:52:01.227 [CM503014]: Call(7): No known route to target: <sip[email protected];user=phone>
18:52:01.226 [CM503010]: Making route(s) to <sip[email protected];user=phone>
18:52:01.225 [CM505001]: Ext.123: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [PolycomSoundPointIP-SPIP_501-UA/3.1.7.0134] PBX contact: [sip:[email protected]:5060]
18:52:01.220 [CM503001]: Call(7): Incoming call from Ext.123 to <sip[email protected];user=phone>
18:51:35.898 [CM503008]: Call(6): Call is terminated
18:51:30.691 [CM503007]: Call(6): Device joined: sip:[email protected]:40600;rinstance=2a252158b4e19f26
18:51:30.690 [CM503007]: Call(6): Device joined: sip:[email protected]:5060
18:51:30.685 [CM503002]: Call(6): Alerting sip:[email protected]:40600;rinstance=2a252158b4e19f26
18:51:30.537 [CM503025]: Call(6): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=2a252158b4e19f26]
18:51:30.492 [CM503016]: Call(6): Attempt to reach <sip[email protected];user=phone> failed. Reason: Not Found
18:51:30.491 [CM503014]: Call(6): No known route to target: <sip[email protected];user=phone>
18:51:30.490 [CM503010]: Making route(s) to <sip[email protected];user=phone>
18:51:30.487 [CM503001]: Call(6): Incoming call from Ext.123 to <sip[email protected];user=phone>
(Phone-number i put in of course so no one calls my home line)
But i have called both local and US LD and this happens every time... From what I read it could be my Outbound Rules so here is my Outbound Rules,
Now I have one for LD as well but i just need to know why my local calls are not working and then i am sure LD will be fixed. Also 719 is my local area code.
I don't have a Gateway setup, No Digital Receptionist, No Bridges, No Inbound Rules, & No DiD's? I have no idea if any of these could be the problem.
Firewall stuff,
I have 5060 (UDP/TCP),5090 (UDP/TCP), & Port Triggering Forwarding of 900-9040 (UDP/TCP) forwarded in my router
Firewall Checker:
3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
<19:02:31>: Phase 1, checking servers connection, please wait...
<19:02:31>: Stun Checker service is reachable. Phase 1 check passed.
<19:02:31>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
<19:02:31>: UDP SIP Port is set to 5060. Response received WITH TRANSLATION 5061::5060. Phase 2a check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:31>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
<19:02:31>: TCP SIP Port is set to 5060. Response received WITH TRANSLATION 5061::5060. Phase 2b check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:31>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
<19:02:31>: TCP TUNNEL Port is set to 5090. Response received WITH TRANSLATION 5091::5090. Phase 3 check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:31>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
<19:02:36>: UDP RTP Port 9000. Response received WITH TRANSLATION 9050::9000. Phase 4-01 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9001. Response received WITH TRANSLATION 9051::9001. Phase 4-02 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9002. Response received WITH TRANSLATION 9052::9002. Phase 4-03 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9003. Response received WITH TRANSLATION 9053::9003. Phase 4-04 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9004. Response received WITH TRANSLATION 9054::9004. Phase 4-05 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9005. Response received WITH TRANSLATION 9055::9005. Phase 4-06 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9006. Response received WITH TRANSLATION 9056::9006. Phase 4-07 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9007. Response received WITH TRANSLATION 9057::9007. Phase 4-08 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9008. Response received WITH TRANSLATION 9058::9008. Phase 4-09 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9009. Response received WITH TRANSLATION 9059::9009. Phase 4-10 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9010. Response received WITH TRANSLATION 9060::9010. Phase 4-11 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9011. Response received WITH TRANSLATION 9061::9011. Phase 4-12 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9012. Response received WITH TRANSLATION 9062::9012. Phase 4-13 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9013. Response received WITH TRANSLATION 9063::9013. Phase 4-14 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9014. Response received WITH TRANSLATION 9064::9014. Phase 4-15 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9015. Response received WITH TRANSLATION 9065::9015. Phase 4-16 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9016. Response received WITH TRANSLATION 9066::9016. Phase 4-17 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9017. Response received WITH TRANSLATION 9067::9017. Phase 4-18 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9018. Response received WITH TRANSLATION 9068::9018. Phase 4-19 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9019. Response received WITH TRANSLATION 9069::9019. Phase 4-20 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9020. Response received WITH TRANSLATION 9070::9020. Phase 4-21 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9021. Response received WITH TRANSLATION 9071::9021. Phase 4-22 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9022. Response received WITH TRANSLATION 9072::9022. Phase 4-23 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9023. Response received WITH TRANSLATION 9073::9023. Phase 4-24 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9024. Response received WITH TRANSLATION 9074::9024. Phase 4-25 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9025. Response received WITH TRANSLATION 9075::9025. Phase 4-26 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9026. Response received WITH TRANSLATION 9076::9026. Phase 4-27 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9027. Response received WITH TRANSLATION 9077::9027. Phase 4-28 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9028. Response received WITH TRANSLATION 9078::9028. Phase 4-29 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9029. Response received WITH TRANSLATION 9079::9029. Phase 4-30 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9030. Response received WITH TRANSLATION 9080::9030. Phase 4-31 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9031. Response received WITH TRANSLATION 9081::9031. Phase 4-32 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9032. Response received WITH TRANSLATION 9082::9032. Phase 4-33 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9033. Response received WITH TRANSLATION 9083::9033. Phase 4-34 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9034. Response received WITH TRANSLATION 9084::9034. Phase 4-35 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9035. Response received WITH TRANSLATION 9085::9035. Phase 4-36 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9036. Response received WITH TRANSLATION 9086::9036. Phase 4-37 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9037. Response received WITH TRANSLATION 9087::9037. Phase 4-38 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9038. Response received WITH TRANSLATION 9088::9038. Phase 4-39 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9039. Response received WITH TRANSLATION 9089::9039. Phase 4-40 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9040. Response received WITH TRANSLATION 9090::9040. Phase 4-41 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9041. Response received WITH TRANSLATION 9091::9041. Phase 4-42 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9042. Response received WITH TRANSLATION 9092::9042. Phase 4-43 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9043. Response received WITH TRANSLATION 9093::9043. Phase 4-44 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9044. Response received WITH TRANSLATION 9094::9044. Phase 4-45 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9045. Response received WITH TRANSLATION 9095::9045. Phase 4-46 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9046. Response received WITH TRANSLATION 9096::9046. Phase 4-47 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9047. Response received WITH TRANSLATION 9097::9047. Phase 4-48 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9048. Response received WITH TRANSLATION 9098::9048. Phase 4-49 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<19:02:36>: UDP RTP Port 9049. Response received WITH TRANSLATION 9099::9049. Phase 4-50 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
Thanks for any help any of you can give me!
EDIT: Totally forgot when someone calls me it says the person at this extension isn't available and automatically sends them to my voicemail and yes i am set as available in 3cx/my personal phone.
Firewall stuff,
Firewall Checker:
