Can't register at Gizmo5 & SIP2SIP
Discussion in 'iOS' started by doraemon, Dec 22, 2010.
  1. doraemon
    Dec 21, 2010
    Hello!
    I've installed the 3CxPhone on my iPhone3GS and configured it for Gizmo5 & SIP2SIP.
    But I couldn't register at all. message: "Not Registered"
    My settings are as follows:
    Gizmo5
    User = Gizmo5 user ID 17471115555(replacing with my 1747)
    Password = my Gizmo5 password
    Internal Server = blank
    External Server = proxy01.sipphone.com
    Stun Server = stun01.sipphone.com
    SIP2SIP
    User = SIP2SIP user ID 2233425555(replacing with my 2233)
    Password = my SIP2SIP password
    External Server = sip2sip.info
    Stun Server = proxy.sipthor.net
    Any suggestions to solve this problem?
    Thank you for your support in advance.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,972
    283
    Gizmo5 is not a standards based SIP provider....
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    We just uploaded 1.0.20, which address also the issue you describe, so these days should be available for download (at this moment is "in review" in the Apple Store).
    Once you will install it, what you set here as "Stun server" you will have to set into the newly added "Proxy" field, and let "STUN server" as stun3.3cx.com.
    When you will try the new version, please tell us how is working - thanks.
    Regards
    vali
  4. Vali_3CX
    Dec 12, 2008
    1,528
    71
    OK, 1.0.20 has been approved and is available for download. Please try it and see if is working ok with your providers.
