Can't register SIP Trunk in 3CX hosted PBX - error 504
Discussion in '3CX Phone System - General' started by sumrit, May 24, 2016.
  1. sumrit
    May 23, 2016
    I am running the trial version of 3CX hosted pbx considering to buy for my organization. I have been trying to register my SIP account to the 3CX server manager many times but I can't.
    The log shows ;
    Call or Registration to CAT has failed. sip:+66202630xx@catnextgen.com:5060 replied: 504 Server Time-out - DNS Problem; from IP:202.129.61.102:5060
    or with some setting ;
    Call or Registration to CAT has failed. sip:+66202630xx@202.129.61.102:5060 replied: 482 Loop Detected; from IP:202.129.61.102:5060
    while I can normally register in other app e.g. zoiper and some other app with the same setting - see log and setting picture;
    2016-05-24 13:12:03: Account [email='+66202630xx@catnextgen.com]'+66202630xx@catnextgen.com[/email]' registered (SIP), new voice messages: 0, old voice messages: 0.
    Please anyone give me a clue to go through this.
    Thank you very much.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    From the information you provided i can see that that the PBX is getting a reply form the providers IP address ( 202.129.61.102)
    I have done an nslookup on my side and i can see that FQDN sip1.catnextgen.com resolves to the above IP address.
    On both calls since the provider is replying back with "504 Server Time-out" and "482 Loop Detected" this is something that needs to be checked on their side and clarify the reason they send these replies to the PBX.
    From the PBX point of view i can see that on the outbound proxy you are using FQDN sip1.catnextgen.com.
    Based on the attached screenshots i would recommend using IP address 202.129.61.118
    Give it a try like this and provide us a feedback.
  3. sumrit
    May 23, 2016
    Thank you very much, YiannisH for your quick response
    Actually, I have tried to put value in many combinations, and yes, this gives the same result ;
    Call or Registration to CAT has failed. sip:+6620263099@catnextgen.com:5060 replied: 504 Server Time-out - DNS Problem; from IP:202.129.61.118:5060
  4. YiannisH_3CX
    May 10, 2016
    7,783
    561
    As i mentioned above, at this point the best course of action is contacting your provider to clarify why they are sending this reply.
    I recommend to proceed with that and let us know
