Can't remove custom Provisioning tamplates
Discussion in '3CX Phone System - General' started by jasonsomers, Oct 21, 2015.
  1. jasonsomers
    Oct 21, 2015
    7
    Running V14 - VIrtual PBX.
    On my first instance - I have created a few custom templates for the Yealink T46, but they have errors in them and I would like to remove them completely.
    Found that in the Virtual PBX install, the custom files are located at:
    C:\ProgramData\3CX\Instance9\Data\Http\Interface\provisioning\qdfqsfsqwfefew\CustomTemplates\phones
    However - deleting the custom XML files from here does NOT remove them from the drop down list under Settings->Provisioning templates.
    How do I get rid of these extra templates? They are really clogging things up here.
    -Jason
  2. tsteffens
    Jul 14, 2011
    85
    After you remove the template go to services in windows and restart the web service. That worked for me.
  3. jasonsomers
    Oct 21, 2015
    7
    Can you be more specific? The "Web Management Service"?
    Thanks,
    Jason
  4. tsteffens
    Jul 14, 2011
    85
    Mine is abyss web server service. If you run iis I would imagine it being the world wide web publishing service.
