Can't Restore
Discussion in '3CX Phone System - General' started by Glennbw, Sep 10, 2016.
  1. Glennbw
    Sep 9, 2016
    7
    I have the back up files but the restore button is greyed out (V15). Tried putting the file path in the search bar but still nothing. Any clues??
  2. Glennbw
    Sep 9, 2016
    7
    It seems only backups created since I reinstalled will show and un grey the restore button. Does anyone know how to show backups from the previous install of v15?
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Try copying your backup into the default backup location and see if that works. the default location is C:/ProgramData/3CX/Instance1/Data/Backups
