Can't save the MAC address in Povisioning
Discussion in '3CX Phone System - General' started by cdrichla, May 28, 2008.
  1. cdrichla
    May 25, 2008
    33
    I'm in Beta 6 and tryng to add a MAC address in Provisioning. I can add an extension without a MAC address and it saves fine but if I input a MAC address and hit OK the screen flashes back to the Add extenstion setup screen. I'm registering a Polycom IP-501 which isn't listed in the "Models" drop down. If I choose a model, it will save the MAC address but if I leave it on "no model" it won't save it.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    Do you have an NFR or commercial license key? If yes did you activate it? Note that this feature only works in the commercial editions
