Can't search for "ring but no voice"
Discussion in 'Windows' started by DeWild1, Mar 27, 2009.
  1. DeWild1
    Oct 31, 2008
    86
    "The following words in your search query were ignored because they are too common words: but ring voice no."
    Come on.. If my search is toooo exact, it will not result in anything.. :roll:
    I have 4 XP and 1 vista that have all had the same problem...
    Had 3cx 7 client.. Installed Beta... removed 3cx7... (Some left it installed), then I would make a call, get ringing, then when it answers, (digital receptionist or outside call). no sound,, then on one, I would get voice, (mic) but not both.. (IE I can not hear the other caller)..
    At first I thought it was all my BT stuff, (That I have working perfectly on my Vista).. But then I just used the sound card and took out the BT USB Plantronics device...
    Before I played with beta, the 3cx 7 was working.
    On one vista, I removed the MS BT stack and used a Toshiba one and the BT USB from plantronics and its working.. On the XP machines, nothing seems to work, can not even use the 3cx.. ugg, I am tierd.. But this should work and I am setting it up right...
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    68
    Hi, DeWild
    You already know how to use the Voip Phone, so I suppose I don't tell you something new here, but please check
    1 - do not use STUN on the phone on intranet connections (that means, the PBX address should be set into the "I am in the office - local IP" field).
    2 - be careful if you're using the 3.1.xxx Voip Phone and the connection is tunneled - 3.1.xxx's tunnel works - on audio - only with PBX RC2 and above.
    Regards
    vali
