Can't see IP address
Discussion in '3CX Phone System - General' started by ao, Dec 6, 2011.
  1. ao
    ao
    Aug 10, 2010
    6
    G'day,
    Question for the community.
    Simple setup, but can't seem to provision a CISCO SPA5088G.
    Setup:
    1. Cable modem connected to a Linksys WRT3GN
    2. Port one from the Linksys device to my laptop
    3. Port two from the Linksys device to my CISCO ipPhone
    4. Can't see the IP address for the CISCO device in 3CX during the provisioing stage
    5. Both the 3XC server and CISCO phone have a static IP address
    What gives?
    Thanks for your assistance!
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    Not 100% sure what you mean here.
    So your phone is remote from your 3cx server or on the same network?
