Can't send faxes
Discussion in '3CX Phone System - General' started by Alexord, Oct 22, 2008.
  1. Alexord
    May 28, 2008
    19
    I use 3 different providers that claim to support T.38 but with all of them I unable to send faxes :(
    either I got error "No RTP packets were received" or "400 Bad Request".
    One of providers lets to choose fax mode T.38 or transparent. Neither works with the same error "no rtp packets.."
    From a provider's support I received this:
    > We need 3CX to initiate a G.711 call and then send a reinvite on T.38.
    > We are not that familiar with 3CX are you able to ask 3CX support if this is possible?
    Is it possible to configure lake that?
    Please, give me a hint! I've spent 3 working days on this, and have no idea any more :(
    Some logs:
    11:56:49.311 MediaServerReporting::RTPReceiver [MS105000] C:324.1: No RTP packets were received:remoteAddr=192.168.0.200:10038,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7012
    11:56:49.311 Call::Terminate [CM503008]: Call(324): Call is terminated
    11:56:49.295 Call::Terminate [CM503008]: Call(324): Call is terminated
    11:56:49.202 CallCtrl::eek:nLegConnected [CM503007]: Call(324): Device joined: sip:a7275sEuuoAUoV7d@sip.gafachi.com:5060
    11:56:49.202 CallCtrl::eek:nLegConnected [CM503007]: Call(324): Device joined: sip:888@192.168.0.200:5100;user=phone
    11:56:08.734 Line::printEndpointInfo [CM505003]: Provider:[Gafachi] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:192.168.0.200:5060]
    11:56:08.734 CallCtrl::eek:nAnsweredCall [CM503002]: Call(324): Alerting sip:a7275sEuuoAUoV7d@sip.gafachi.com:5060
    11:56:05.843 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(324): Calling: VoIPline:0078123200031@(Ln.10011@Gafachi)@[Dev:sip:a7275sEuuoAUoV7d@sip.gafachi.com:5060]
    11:56:05.812 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:770078123200031@192.168.0.200:5060;user=phone]
    11:56:05.812 CallCtrl::eek:nIncomingCall [CM503001]: Call(324): Incoming call from Fax.888 to [sip:770078123200031@192.168.0.200:5060;user=phone]
    16:34:35.811 Call::Terminate [CM503008]: Call(237): Call is terminated
    16:34:35.811 Call::RouteFailed [CM503015]: Call(237): Attempt to reach [sip:990078123200031@192.168.0.200:5060;user=phone] failed. Reason: Reason Unknown
    16:34:35.811 CallLeg::eek:nFailure [CM503003]: Call(237): Call to sip:0078123200031@sip99.mondotalk.com:5060 has failed; Cause: 400 Bad Request; from IP:204.9.202.101:5060
    16:34:34.373 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(237): Calling: VoIPline:0078123200031@(Ln.10009@MondoTalk)@[Dev:sip:8393447@sip99.mondotalk.com:5060]
    16:34:34.358 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:990078123200031@192.168.0.200:5060;user=phone]
    16:34:34.342 CallCtrl::eek:nIncomingCall [CM503001]: Call(237): Incoming call from Fax.888 to [sip:990078123200031@192.168.0.200:5060;user=phone]
    16:33:42.968 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@192.168.0.200:5060 with contact sip:888@192.168.0.200:5100;user=phone
