Can't send RTP stream Error
Discussion in '3CX Phone System - General' started by chrisjr, Apr 24, 2008.
  1. chrisjr
    Jan 23, 2007
    21
    Everything seems to be working fine but callers are saying they can not hear us. I'm also getting some RTP stream errors and don't know if this is the cause.
    14:42:01.156 MediaServerReporting::RTPSender [MS104000] Call(31) Ext.101: (ACTIVE) RTP stream to 192.168.2.14:16480 restored.
    14:41:59.343 MediaServerReporting::RTPSender [MS004000] Call(31) Ext.101: (ACTIVE): Can't send RTP stream to 0.0.0.0:16480 destination unreachable
  2. corotte
    May 2, 2012
    6
    i'm having the same issue here
    on both side (calling and receiving call) no sound at all or some part of it trough my SIP Trunk provider.
    internal call are ok
    here is the log of a call that had no sound (from 3cx extension to external phone number)
    19:50:43.745|.\CallCtrl.cpp(346)|Log2||CallCtrl::eek:nIncomingCall:[CM503001]: Call(3): Incoming call from Ext.10 to <sip:(externalphonenumberhidden)@172.16.0.2:5060><br>
    19:50:43.745|.\Extension.cpp(1407)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.10: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.20943.0] PBX contact: [sip:10@172.16.0.2:5060]<br>
    19:50:43.745|.\CallCtrl.cpp(529)|Log3||CallCtrl::eek:nSelectRouteReq:[CM503010]: Making route(s) to <sip:(externalphonenumberhidden)@172.16.0.2:5060><br>
    19:50:43.745|.\CallCtrl.cpp(708)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503004]: Call(3): Route 1: VoIPline:(externalphonenumber)@(Ln.10002@(siplinename))@[Dev:sip:(my3cxphonenumber)@sip05.unlimitel.ca:5060]<br>
    19:50:47.245|.\SLServer.cpp(805)|Error1|MediaServer|MediaServerReporting::STUN:[MS101005] STUN request failed for ports 9004,9005 on STUN server 'stun01.sipphone.com:3478'<br>
    19:50:47.245|.\SLServer.cpp(805)|Error1|MediaServer|MediaServerReporting::STUN:[MS201000] Use STUN server 'stun.callwithus.com:3478'<br>
    19:50:47.307|.\Target.cpp(441)|Log2||Target::makeOneInvite:[CM503025]: Call(3): Calling VoIPline:(externalphonenumberhidden)@(Ln.10002@(siplinename))@[Dev:sip:(my3cxphonenumber)@sip05.unlimitel.ca:5060]<br>
    19:50:55.995|.\CallLeg.cpp(315)|Log3||CallLeg::eek:nAnswer:[CM503002]: Call(3): Alerting sip:(my3cxphonenumber)@sip05.unlimitel.ca:5060<br>
    19:50:55.995|.\Line.cpp(1455)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[(my3cxphonenumber)] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:(my3cxphonenumber)@(mypublicipaddresS):5060]<br>
    19:50:58.401|.\CallCtrl.cpp(885)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(3): Device joined: sip:10@172.16.0.4:62442;rinstance=427cb3a0d73cdb92<br>
    19:50:58.401|.\CallCtrl.cpp(885)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(3): Device joined: sip:(my3cxphonenumber)@sip05.unlimitel.ca:5060<br>
    19:50:58.557|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [3]<br>
    19:51:00.963|.\SLServer.cpp(823)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004000] C:3.1: (ACTIVE): Can't send RTP stream to 172.16.0.4:40024 destination unreachable<br>
    19:51:00.963|.\SLServer.cpp(823)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004000] C:3.2: (ACTIVE): Can't send RTP stream to 209.217.98.154:14618 destination unreachable<br>
    19:51:00.979|.\SLServer.cpp(823)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104000] C:3.1: (ACTIVE) RTP stream to 172.16.0.4:40024 restored.<br>
    19:51:00.979|.\SLServer.cpp(823)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104000] C:3.2: (ACTIVE) RTP stream to 209.217.98.154:14618 restored.<br>
    19:51:03.463|.\SLServer.cpp(823)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004000] C:3.1: (ACTIVE): Can't send RTP stream to 172.16.0.4:40024 destination unreachable<br>
    19:51:03.463|.\SLServer.cpp(823)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004000] C:3.2: (ACTIVE): Can't send RTP stream to 209.217.98.154:14618 destination unreachable<br>
    19:51:03.479|.\SLServer.cpp(823)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104000] C:3.1: (ACTIVE) RTP stream to 172.16.0.4:40024 restored.<br>
    19:51:03.479|.\SLServer.cpp(823)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104000] C:3.2: (ACTIVE) RTP stream to 209.217.98.154:14618 restored.<br>
    19:51:06.010|.\SLServer.cpp(823)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004000] C:3.1: (ACTIVE): Can't send RTP stream to 172.16.0.4:40024 destination unreachable<br>
    19:51:06.010|.\SLServer.cpp(823)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004000] C:3.2: (ACTIVE): Can't send RTP stream to 209.217.98.154:14618 destination unreachable<br>
    19:51:06.010|.\SLServer.cpp(823)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104000] C:3.2: (ACTIVE) RTP stream to 209.217.98.154:14618 restored.<br>
    19:51:06.026|.\SLServer.cpp(823)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104000] C:3.1: (ACTIVE) RTP stream to 172.16.0.4:40024 restored.<br>
    19:51:08.541|.\SLServer.cpp(823)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004000] C:3.1: (ACTIVE): Can't send RTP stream to 172.16.0.4:40024 destination unreachable<br>
    19:51:08.541|.\SLServer.cpp(823)|Critical0|MediaServer|MediaServerReporting::RTPSender:[MS004000] C:3.2: (ACTIVE): Can't send RTP stream to 209.217.98.154:14618 destination unreachable<br>
    19:51:08.557|.\SLServer.cpp(823)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104000] C:3.1: (ACTIVE) RTP stream to 172.16.0.4:40024 restored.<br>
    19:51:08.557|.\SLServer.cpp(823)|Error1|MediaServer|MediaServerReporting::RTPSender:[MS104000] C:3.2: (ACTIVE) RTP stream to 209.217.98.154:14618 restored.<br>
    19:51:08.604|.\Call.cpp(1396)|Log2||Call::Terminate:[CM503008]: Call(3): Call is terminated<br>
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    In the first posting of the thread, there is no IP associated to the device when the initial stream is started, it shows 0.0.0.0. Unsure as to why it seemed to recover. I guess it possible that:
    1. The 3CX services were starting but not all had completed
    2. DHCP was in process to the device at the exact time the call was going on
    3. Goblins and gremlins
    Take a look at the 3CX server event log and then the system log for the computer itself (not the 3CX activity log) as these may shed some light.
    For both threads, have you tested the firewall checker (recently). The second thread mentions one-way audio which is generally the result of firewall issues.
