Solved Can't send Welcome Email
Discussion in 'iOS' started by RJ Woods, Dec 16, 2016.
  1. RJ Woods
    Dec 16, 2016
    When trying to set up the 3CX app for iOS (iPhone 6 Plus, iOS10, 3CX: v15.2.2.103), I try sending the Welcome Message from 3CX Management Console (V12), I get a message saying 'An exception occurred Error: the remote certificate is invalid according to the validation procedure.'
    I'm out of ideas. Any suggestions?
  2. StefanW
    Jun 2, 2009
    1,222
    93
    your SMTP server in TLS presents an cert which is unknown to your trusted cert store (windows or linux), hense the connection can not be trusted and we drop the connection. Now you have two options:
    a) disable TLS, not so nice but simple
    b) get your hand on the ssl cert your smtp server uses, export it and import it on the pbx host as trusted root cert.
  3. Patricio Leon
    Feb 14, 2017
    Have the same problem, we use G suite. I was working before but at a certain point stop working. Please let me know. Thank you
  4. Rui Pantano Filho
    Mar 16, 2017
    Can they help me how to use the license? i received the e-mail but o don't know what i need to do to active it.
