Can't Send welcome mail. AuthenticationInvalidCredentials: 5.7.0 Denied
Discussion in '3CX Phone System - General' started by sunrise, Feb 22, 2018.
  1. sunrise
    Feb 19, 2018
    5
    My 3cx can't send Email. When I tested "SMTP server 3cx" have error: AuthenticationInvalidCredentials: 5.7.0 Denied
    Then I change update server to https://downloads-global.3cx.com/downloads/v155
    But problem not solved.
    I use Free version and now can't change SMTP to another
    Logs:
    2018/02/22 02:55:03.612|2112|0021|Excpt|MailKit.Security.AuthenticationException: AuthenticationInvalidCredentials: 5.7.0 Denied
    в MailKit.Net.Smtp.SmtpClient.Authenticate(Encoding encoding, ICredentials credentials, CancellationToken cancellationToken)
    в MailKit.MailService.Authenticate(String userName, String password, CancellationToken cancellationToken)
    в GenericUtilsNet.MailTemplateSender.Send(XDocument template, Func`2 getParameter, String mailTo, IEnumerable`1 attachments)
    в _3cxSystemService.ExtSheduller.WelcomeEmailSender.SendWelcome(Extension ext)
    в _3cxSystemService.ExtSheduller.WelcomeEmailSender.SendingProc()
  2. StefanW
    Jun 2, 2009
    1,216
    88
    5.7.0 is a missmatch of your FQDN IP to the IP you are sending the eMail from. Check under Settings Network that the IP there is correct and your FQDN resolves accordingly.
  3. sunrise
    Feb 19, 2018
    5
    What should I do if the Crimea is currently under sanctions and without VPN I can not update and send E-mail. But when connect via VPN, this error appears.
  4. StefanW
    Jun 2, 2009
    1,216
    88
    you might set as public IP the VPN endpoints IP. Dependently if you have remote connected devices using the FQDN, then this would work.
