Can't unregister on version 1.1.5 [Solved]
Discussion in 'iOS' started by rhjaeger, Apr 25, 2012.
  1. rhjaeger
    Nov 9, 2011
    I just upgraded to version 1.1.5 and now I can't unregister the phone. Am I missing something?
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,434
    61
    Re: Can't unregister on version 1.1.5
    How do you try/attempt to unregister the phone?
  3. StefanW
    Jun 2, 2009
    1,198
    79
    do you refer to the not more existing "Exit" button?
    Apple told us to remove this, the main function of the phone is to be reg. so there is no other use for this app.
    you may can reg to an dummy account to unreg. the existing one...
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,960
    180
    i liked the "exit" button - in case I was going to bed for the night - easy way to turn it off. now I must goto the multitasking toolbar and exit the app - or do the "hack" of a dummy account.
    it does seem more stable though. thanks for all the efforts.
  5. Vali_3CX
    Dec 12, 2008
    1,434
    61
    As Stefan said, it was an explicit Apple requirement. Please read my old post from January
    http://www.3cx.com/forums/new-3cxphone-ver-1-1-4-for-iphone-available-22507-15.html#p118678
  6. craigreilly
    Feb 1, 2012
    2,960
    180
    I understand Apple - we have several apps out there and sometimes they come back with the craziest little issue.
    I can live without the 'Exit' button - the performace is so much improved.
    Thank you.
  7. rhjaeger
    Nov 9, 2011
    Won't the phone always being registered reduce the battery life of the iPhone?
  8. StefanW
    Jun 2, 2009
    1,198
    79
    in our test the running in the background reduced marginal the live time.
    The hole point is that the app is running and you can receive calls, isnt it?
    if you dont wanna use the app anymore you need to terminal via the task manager.
    -->Its an Apple req. - it was not our idea to remove the button...
