cant upgrade 14 > 14 SP1
Discussion in '3CX Phone System - General' started by cyberhostpro, Oct 30, 2015.
  1. cyberhostpro
    May 6, 2012
    12
    HI
    I cant upgrade to SP1, when i click download it gives a weird output.
    Screencast: http://screencast.com/t/UXvLvExumGrW
    Has anyone else saw this before? hopefully someone knows of a fix for me :)
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
    Have you tried downloading the full package from http://downloads.3cx.com/downloads/3CXPhoneSystem14.exe and installing this , instead of just the SP1 patch via the console
  3. tsukraw
    tsukraw New Member
    Mar 9, 2012
    190
    7
    I had a customer getting the same thing when trying to upgrade to SP1.
    In my case i did just that, ran a backup, downloaded the new install and did a full re-install/restore.
    Kind of odd that it needed that but it did work.
