Solved Can't use phones after import
Discussion in '3CX Phone System - General' started by c.holloway, Oct 16, 2017.
  1. c.holloway
    Oct 24, 2014
    35
    Good afternoon! I'm setting up a new v 15.5 3CX system for a client and i'm having issues after importing users, extensions, and phones via a csv file. The import works just fine but after importing I can no longer manage the extensions or phones. When attempting to edit an extension I get an XML parsing error that is in the attached screenshot. Has anyone run into this before?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    Hello @c.holloway
    Does your csv file have double quotes on any of the values by any chance? For example value ProvType=""0"" where it should be ProvType="0"
  3. c.holloway
    Oct 24, 2014
    35
    YiannisH,
    It does not. I have found that I can do the import so long as I leave the phone options field blank. However, if I do this I then have to go to each phone and set up codec and time format preferences and I'd rather it all just be right after the import. Here is the text of my phone options field
    <PhoneDevice ProvType="0" PhoneLanguage="English" XferType="BXfer" RingTone="Ring 1" DateFormat="WWW MMM DD (Mon Jan 15)" TimeFormat="24-hour clock" PowerLed="Both (Voicemail and Missed calls)" Backlight="30 seconds"><DynamicOptions /><CodecsPriority><Codec Priority="1" PriorityVarName="codec1" DisplayText="PCMU" PayloadTypeName="payload1" payload="PCMU">0</Codec><Codec Priority="2" PriorityVarName="codec2" DisplayText="PCMA" PayloadTypeName="payload2" payload="PCMA">8</Codec><Codec Priority="3" PriorityVarName="codec3" DisplayText="G722" PayloadTypeName="payload3" payload="G722">9</Codec><Codec Priority="4" PriorityVarName="codec4" DisplayText="G729" PayloadTypeName="payload4" payload="G729">18</Codec></CodecsPriority><BLFS OwnBlfs="0" /></PhoneDevice>
  4. YiannisH_3CX
    May 10, 2016
    5,425
    352
    Can you send me your CSV file in a private message so i can check and see what is wrong? You can upload it to a web transferring service and provide me with the download link
  5. SeanCTS
    Oct 29, 2017
    BTW, I also get the same thing. It seems that whenever a phone is provisioned, when exported, the XML is stored improperly in the CSV, which causes issues upon importing. YiannisH_3CX, I'll send you my CSV via pm as well.
  6. YiannisH_3CX
    May 10, 2016
    5,425
    352
    @SeanCTS
    Please try the file i sent you and let me know if that works for you.
  7. RyanOpus
    Nov 1, 2017
    Im getting a similar issue when ever i provision phones with an import even if i create a extension in 3cx console, export it. Delete the extension from the console. And import the single extension I have just exported it throws this error. When trying to edit the extension. This is version 15.5
    Are you aware of any issues that could cause this and any possible resolution
  8. RyanOpus
    Nov 1, 2017
    looks like it may be an issue with the phone settings string. remove this and i can edit the phone. here's the string the export provides.
    <PhoneDevice ProvType="0" PhoneLanguage="English" XferType="BXfer" RingTone="Ring 1" DateFormat="WWW MMM DD (Mon Jan 15)" TimeFormat="24-hour clock" PowerLed="Both (Voicemail and Missed calls)" Backlight="30 seconds" ScreenSaver="30 seconds"><DynamicOptions><option name="vlanwanport" value="False" /><option name="vlanwanid" value="1" /><option name="vlanwanpriority" value="0" /><option name="vlanpcport" value="False" /><option name="vlanpcid" value="1" /><option name="vlanpcpriority" value="0" /></DynamicOptions><CodecsPriority><Codec Priority="1" PriorityVarName="codec1" DisplayText="PCMU" PayloadTypeName="payload1" payload="PCMU">0</Codec><Codec Priority="2" PriorityVarName="codec2" DisplayText="PCMA" PayloadTypeName="payload2" payload="PCMA">8</Codec><Codec Priority="3" PriorityVarName="codec3" DisplayText="G722" PayloadTypeName="payload3" payload="G722">9</Codec><Codec Priority="4" PriorityVarName="codec4" DisplayText="G729" PayloadTypeName="payload4" payload="G729">18</Codec></CodecsPriority><BLFS OwnBlfs="0" /></PhoneDevice>
  9. YiannisH_3CX
    May 10, 2016
    5,425
    352
    Hello @RyanOpus
    Edit the .csv file with a simple file editor like notepad++ and check if the values have double " that might not appear in excel. If so then delete them leaving only single " and try again.
  10. RyanOpus
    Nov 1, 2017
    Thank you for the response but receive the same error
  11. RyanOpus
    Nov 1, 2017
    found the issue had also put " on either end of the string
  12. YiannisH_3CX
    May 10, 2016
    5,425
    352
    That is correct, you the beginning and end of the string do not require ". Glad the issue is resolved
