Can't work with 'create_fwd_profile' in C# API
Discussion in '3CX Phone System - General' started by yancey, Aug 13, 2014.
  1. yancey
    Aug 13, 2014
    I try this sample . create the same extension , but the forwarding rule never change . why ?
    C:> OMSamples.exe create_fwd_profile
    extensions > choice 'extension' > edit > forwarding rules .... never change
    Help! Any idea ?
