Catch All Function
Discussion in 'Ideas' started by timmbo, Sep 6, 2017.
Catch All Function 5 5 2votes
5/5, 2 votes
  1. timmbo
    Aug 25, 2017
    99
    47
    here in Austria you get from the Regulator/Provider a Number, let's say +43720123456, and all Digits after ths Number it can be in this case from 0 to 999 are routed to this VoIP-Account.
    But in the Company they are only 50 Extensions, the other 949 Numbers going nowhere, and exactly this is the problem, the customers wanna catch those Callers also.
    In my opinion i think a variable can make the deal and all Extensions are not set goes to the Mainextension.
    Bye
    Timm
    ITW likes this.
